7 Attachment(s)
(Two) Butler Pinto 2L Motors and Fast Forward Aluminum Head
Note: Packing and shipping these are a pain and expensive. So we could arrange for my delivery to Road Atlanta or another option is you could engage Sam Nelson/Nelson Engines to build you a motor. Nelson in Atlanta builds Pinto Motors for many SCCA competitors.
Two Butler motors for re-assembley
(1) One former Butler motor was being prepared for re-assembly by prior owner. It appears block was prepped, crank prepped (still in box), new pistons and rods assembled, new bearing and piston rings in boxes, and other miscellaneous items. With Iron head assembled but needs refresh. Includes intake manifold, recently rebuilt Weber carb with brass floats, distributor, other miscellaneous items. Choice of metal generic pan or Swift Cast Aluminum Pan $2,000
2) Former Butler Motor disassembled. Block, crank, 6 used rods and pistons still assembled (not sure what’s useable), iron head fully assembled. Will include pan that is not purchased with motor above. $1,500
3) Fast Forward aluminum head assembled still in shipping box purchased from Elite/Steve Knapp. Has stock cam as required. Note form Elite says all new ARE bolts including cam sprocket. Appears ready to bolt on $1,500
or $4,500 for all.
