Plastic coated aeroquip braided stainless
I'm replacing my oil pressure gauge and re-plumbing my oil pressure line. I have a roll of -3 line and the fittings to assemble. The braiding is coated with plastic to prevent abrasion.
The challenge is removing the plastic coating so the braid will fit into the fitting nut so I can assemble it. I cut with a dremel abrasive wheel, but the coating will not allow me to insert the end of the line into the nut. Tape around the cut end made the problem even worse. Should I heat the plastic so it melts as it slides into the nut?
TIA for the help.
