Does anyone know what the plug is on the Zetec or MZR crank sensor? And, where the best place to source it?
Thanks! To confirm, that plug is on the crank sensor side, not the harness side? I'm not near my car
That is the harness connector part number, the sensor coupler is: MS3470L8-98P.
Make sure that you get the correct crimp tool for the M39029 spec contacts. I work with this kind of stuff weekly-I can let you know what you need to order if need be. They can be a PIA to look up.
After looking into how tricky it is to wire the plugs...I opted to send them to Zentec wiring to be done properly.
