I am selling Chuck Horn’s Honda powered Swift DB6 Formula Ford for his wife. This car has set many track records, won in excess of 40 races, and won 6 San Francisco Regional Championships. Chuck ran in the SCCA Runoff’s National Championship twice finishing 3nd in 2014 and finished 3rd in 2018 after running second most of the race until spinning in oil on the last lap. This car has the current track records for Thunder Hill Raceway on the 3 mile course and the 4.5 mile course. In 2023 Chuck set the current track record for Laguna Seca. Car is well sorted and comes with a very large spares package. Price - $45,000.
Call Neil at Porter Racing/Pacific Crossle' Inc. - 209 756-7373
This car has many updates as well as several frame modifications to increase chassis stiffness. Car features include:
- AP aluminum calipers – LD20 Front LD19 Rear
- TTX 36 Ohlin shocks
- Spare - Penske 8750 Piggy-Back Shocks with Hyper Coil springs
- Fast Forward uprights – front and rear
- Fast Forward driveshafts and hubs
- Floating disc brake rotors
- Custom made Air Intake Box with K&N panel air filter
- Aim Camera System
- Solo Data System
- Motorola Digital Radios System – Includes radios and chargers
- One set like new Mag OZ wheels
- One set Panasport Magalite wheels
- New transmission case
- Externally adjustable suspension push-rods
- Front and Rear cock pit adjustable sway bars
- Carbon Fiber Mirrors
- Body NACA Duct panels
- Sabelt CamLock seat belts – good through 2027
- Tall Roll Hoop – 2” taller than stock
Spares include:
- Spare Honda engine
- Spare high downforce tail, side panels, and roll hoop cover
- Spare stock air filter housing and filter
- 2 - 5 gallon fuel jugs
- 2 – spare heat shields
- 1 – Spare externally adjustable suspension push-rod (front)
- 1 – Spare externally adjustable suspension push-rod (rear)
- 2 – Spare front toe links
- 1 – Spare upper front a-arm (left or right)
- 1 – Spare lower right front a-arm
- 1 – Spare lower left front a-arm
- 1 – Spare upper rear a-arm (left or right)
- 1 – Spare lower right rear a-arm
- 1 – Spare lower left rear a-arm
- 1 – Spare nose
- Manual fuel pump for fueling car
- Aluminum Gear change tray
- Spare Alternator
- Spare pair of mirrors
- 3 – Master cylinder rebuild kits
- Spare c/v boots
- Spare brake lines
- 2 new O2 sensors
- 4 used O2 sensors
- 8 rebuilt fuel injectors
- Spare used fuel injectors
- Large bag of front alignment shims (30+)
- Large bag of rear alignment shims (30+)
- 3 – spare front sway bars
- 3 – spare rear sway bars
- 4 – spare rear upright drive flanges
- 1 – exhaust pipe deflector
- Bag of bolts and body mounts
- New and used front and rear skids
- New Honda temp sender
- Misc used engine and suspension parts
- Spare sway bar blades
- Spare fuel filters and fuel filter housing
- Spare used brake rotors
- Ohlins Canister inflation tool kit
- Ohlins Shock adjuster wrench
- Penske shock inflation tool
- 17 pairs of shock chassis spring sets – various spring rates
- Pair of ERS shock chassis springs
- Pair of take-up shock chassis springs
- Box new and used rod ends and AN hardware
- Rolls of gray and red vinyl body wrap
- Car cover
- Spare sway bar cable
- 20 gear sets
- Power inverter
- 4 manual tire pressure gages and 1 electronic tire pressure gage
- Shock spring pinch adjuster tool – aluminum
- Misc used rod ends
- 2 Honda Restrictor plates
- 1 Longacre Tire Durometer tool
- Spare Honda Head and rockers
- 1 – K&N filter recharge kit
- 1 – spare K&N panel filter
- 3 - misc spare mirrors
- 1 – Oil filter canister cutting tool (to cut open oil filters for inspection)
- 1 - Used master switch
- 1 - Used lightened c/v joints
- 1 - roll of safety wire
- 1 – custom clutch dead pedal
- 1 – used gun drilled drive shaft
- 1 – Honda engine valve adjusting tool
- 1- set of aluminum AN wrenches (for oil lines)
- 1 – bag of zip ties (100)
- 1 – oil filter wrench
- 1 – Wheel nut torquing socket
- 1 – Leak Down Gage
- 2 – Fuel sample port hoses with quick disconnect
- 1 – Small box of rivets and rivet gun
- 8 – shock bushings
- 1 – Schrader valve tool kit
- 1 – Led work light
- 1 – Longacre Tire scriber
- 1- Race car quick jack
- 1 – Fiberglass repair kit
- 3 – spare tail spoilers
- 1 – spare nose crush box
- 1 – box car care products
- 2.5 gallons of racing engine oil
- 4.5 gallons of racing gear oil
https://www.apexspeed.com/forums/att...d=113752&stc=1
https://www.apexspeed.com/forums/att...d=113751&stc=1
- https://www.apexspeed.com/forums/att...d=113750&stc=1
- https://www.apexspeed.com/forums/att...d=113749&stc=1
- https://www.apexspeed.com/forums/att...d=113748&stc=1
- https://www.apexspeed.com/forums/att...d=113745&stc=1
https://www.apexspeed.com/forums/att...d=113746&stc=1
