3 Attachment(s)
about breather tanks overflow
Hi guys.
i have some issues with the breather tank in my f3000.
After full car rebuild, i tested on small track and notice that my breather tank was overflowing as the catch tank was full in term of some minutes. so i replaced with slighly bigger one and removed some oil from dry sump and testing at home i can still see that the breather tank is filling quickly with aprox 5000 rpm or above for some seconds and oil stays at same level when i release and i leave it at idle. the tank is connected with the top of the drysump and also has a breather hose.
im concern that i can not take out more oil as the level is almost at bottom (aprox 4cm above) when not running, however i tried to measure the level at ldle condition but no way to see it with a camera
if the sump is overflowing and filling the breather tank which is higher of breather hose why i can not see oil on breather hose.
When at idle breather tank does not empty ??
breather tank is 1l, transparent hose is the breather one
some pics of the setup and the amount of oil some minutes after stopping engine.
https://www.apexspeed.com/forums/att...d=111185&stc=1https://www.apexspeed.com/forums/att...d=111186&stc=1https://www.apexspeed.com/forums/att...d=111187&stc=1
Yes! to a schematic diagram
Quote:
Originally Posted by
Rick Kirchner
maybe I'm mis understanding things here - but the large "tower" on top of your tank is not any tank, it's the air/oil separator. Your oil enters from the scavenge stages tangentially into the tower, oil swirls into the tank below. there's usually a line off he top of this tower that takes the air into the overflow tank, and that tank is usually vented to the atmosphere, either through a filter or just a simple hose. You should draw out your entire oil/vent system and post, it will be a lot more informative.
A schematic of the actual oil system configuration would certainly help the remote diagnosticians here on ApexSpeed. Noting on that schematic details [like hose inside diameters, content of lines (oil, scavenge oil, air), restrictors in any paths, etc.] would all be helpful.
Lee
