1 Attachment(s)
RT5 Package
1988 Ralt RT5 vintage, club racing package. Pro History Jordain, Crow. Low time 1900, Fresh 1600. Enough spares to build a 3rd motor. Enclosed trailer, 11 totes of spares, 7 page list. Everything you could want to go racing.
Asking $43,500
Contact Mark Green pitonview@yahoo.com
The Bernard Jourdain/Stuart Crow car?
Is this the Crow car that won the last-ever Pro championship?
Classified ads are required to have an asking price.
KR
5 Attachment(s)
I've traded emails and had a phone call with Mark.
His asking price is $43,500
The motor in it is a 1.9
The gears are Mk9 (not Mk5)
The wheels are 8's and 10’s.
The Pods may be the originals and not 86's, or ?
So the car is an honest ex-pro RT5 time capsule run to the present
The major mod, the SDS Injection/Ignition controller is a major plus
It looks fairly valued at his asking price
It looks like an Insane! value considering how F'ing Awesome these cars are AND the full package
Those last RT5's, like this one, are the Ultimate RT5 with every last thing RT learned about this platform.
https://www.apexspeed.com/forums/att...d=109558&stc=1https://www.apexspeed.com/forums/att...d=109559&stc=1https://www.apexspeed.com/forums/att...d=109560&stc=1https://www.apexspeed.com/forums/att...d=109561&stc=1https://www.apexspeed.com/forums/att...d=109562&stc=1
Ralt RT5 732 Spares List
Installed in car:
Current belts
SDS engine management system
Quaife LSD
New Fire System
Separate parts:
Complete fresh 1600 motor
Stocl 1600 block
NOS 1600 head
Bertil SV head repairable
Spare Nose
Spare front wings {3}
Spare rear wing elements repairable
Spare roll hope stock Ralt
Three sets of wheels two with slicks one with rains
Set up notes
Spare rub strips
Support:
Large enclosed trailer
7500 w generator
Longacre Scales
Set up rack
Tire rack
Tire trees (2)
Winch
Fuel transfer pump
5 gal. Fuel jugs (2)
Funnels
Approx. 25 gal. Sunoco 118 race fuel
Tie downs
Gear Box
28+ gear sets
Hewland set up jig
Spare ring and pinion
Spare carrier
Spare lay shaft
Spare dog ring
Spares Box 1
Cam and layshaft gears (6)
Rear main seal housings (10)
Front seal housings (6)
Jack shaft seal housing
Bertil Motronics distributor mount
Crank gears (3)
Crank end plaay shims
Cam seal repair kit
Timing belt guard
Brabham style dry sump pan pump
Jack shaft
Ring sets
Main caps and bolts
New rod bolts
Valve springs and retainers
Camshafts Bertil (2)
Tensioner
Fuel filters (5)
Spares box 2
Rear up right
Front up right
Bump steer tool
CV joints (2)
Control arms (3)
Body mount brackets (5)
Axle shaft
Shocks (2)
Sway bar mounts (7)
Axle stub
Lower links (2)
Spares box 3
Hewland set up jig
Ring and pinion
Brake rotors (7)
Open differential carrier
Spares box 4
New set of main studs
Cam gear
Motronics pick up
Bertil Cam
Water pump
Harmonic balancer
Tensioner
Jack shaft end seal and housing
Misc. Dry sump parts
Zink crank fire pick up
Fly wheel
Lifters
Forged rods (7)
Pistons (4)
Stock rod
TPS linkage
1600 piston ring set
Pilot bearings (2)
Jack shaft
Tilton pressure plate
Water outtets (2)
Belt tensioner (2)
Crank gears (2)
Water pump gears (2)
Spares box 5
Cam Gear
Head studs
Rear seal
Motronics cable
Valves and lifters
Main studs
Dry sump pans (2)
Valve covers (2)
Water pump
Jack shaft
Belt guide
Oil filter
New head studs
Radator cap
Connecting rods (2)
Spares box 6
Oil cooler (2)
Oil thermostat
Crankshaft
Coolant hose
Water pump assembly
Coolant outlets (2)
Expansion can
Original Ralt steering wheel
Valve springs and guides
Rod bolts
Valve train parts
Spares box 7
Spare seaat belts
Radiator cap
Rain lights
Tensioner
Coolant temp sensor
Water outlet
Bedded brake pads
Starter solenoid
Pulleys
Spares box 8
28 suspension springs
Spares box 9
Gaskets
Bearings
Wing mounts
New piston set
Dry sump pan
Spares box 10
Motronics control box
Air filter
Fire bottle
Motronics ignition parts
Fuel rail
Spares box 11
Remaining misc. Parts TBD,
