Wanted open top steering wheel, and VD Center lock wheels for FF
Not sure if this is an option for you but I cut the top off of a normal wheel, then dipped the cut ends in Plasti-Dip. Worked fine for me.
Another option in the same vein as RussMcB's suggestion, is to cut of the upper section of your existing steering wheel, wrap tape around the cut-off ends (forming a well) and filling the 'well' with epoxy. You can then then contour the cured epoxy to smooth the edges. I got this tip from another poster on APEX and it worked well for me.
-Jim
They also make vinyl end caps that can be slipped over the cut sections and glued in place..
https://img.uline.com/is/image/uline/S-11364?$MediumHD$
