2 Attachment(s)
Wanted Jongbloed 202 cast center(s)
I'm hoping someone has some 202 casting versions still lying around that aren't cracked or haven't been made into clocks or paper-weights! These were popular way back when on Swift DB4s and others with 3.5" pin drive circle
I need at one to finish a set of 12 wheels, but will buy more if you have them so I have spares.
3.5" bolt circle of (8 or 12) 0.5" pin drive holes
Center is 2.25" ID
(18) 0.25" rim half mounting holes.
Note that in my pictures here, the pin drive holes are drilled all the way through to the front.
That's not necessary in the one that I buy. I can drill them.
