15 Attachment(s)
1989 Citation Roller with Engine for Rebuild- $3500
EDIT- Mitchell Motor and Exhaust are sold. Selling remaining roller for $3500 with complete torn down 1200 motor for rebuild. Have complete exhaust that will go with car but will need some modifications to fit. Good deal.
Listing my Citation with a ton of mods.. Driverz Cup Wheels and Tires stay with me- buying another car and need them!
I am located in Gainesville, Georgia. I have done so much to this car it’s going to be difficult to remember it all. I bought this car for drivers school last year - made it through the weekend- got it home- and immediately took it all apart.
-I put a momo mod 12 steering wheel in- 275.
-I put 2 brand new wilwood brake cylinder kits in- 200.
-As well as all new braided stainless hose- 75.
-New wilwood clutch slave cylinder- 100.
-I rebuilt the dash and redid the wiring. 3 times. What we have now is a dual digital oil temp and oil pressure garage- easy to see- as well as a warning light. All switches are aircraft grade and waterproof. Dash is wrapped in carbon. Last dash was actual carbon- but this one turned out better- so we are sticking with it. You’re welcome to have the carbon one as a backup.
-The body was sanded to the glass (all 7 coats of paint- nightmare!) primered- and done in black. The graphics are vinyl and can be easily removed. I did my best to fix all the cracks and knicks- but there’s some small ones there- as you would expect with a car of this age. I then went about closing off the naca ducts and doing some better cooling scoops. Total cost of that was about 800- scoops added from Ray- call it over a thousand. Changed all the dzus fittings as well. That was a blast. But you’re ready to go on that now.
While that was off- I went ahead and sent the rear Fox shock and spring off to Anze in Florida. It was rebuilt to vee spec and it has a new 10 inch hyperco spring at 150lbs. Now has 2 races on them. Dyno sheet will be included. Rebuild and shock cost - 453
Brake drums- 2 races - new on the front. New on the rear. From DIetmar. They aren’t crap. 200.
Brake shoes- will include never used porterfields for front and some golds for the back- 300.
Front shocks- 5 race weekends- went with QA1’s -double adjustable. DD 303 x2- 620
This car has passed its 2023 annual inspection and comes with a log bok. It’s a conversation starter. If you’re not into the livery- just peel it off and make it your own. Won’t hurt my feelings a bit. Will need new belts midway through next year. Fire suppression system is good to go. Fuel tank- not sure- it ain’t leaking and the foam is all there- nothing in the fuel filter- so I think it’s still hanging in there fine- but I wanted you to know I didn’t check it because it hasn’t caused a single problem! This car has finished every race for me I’ve ever started in. (All 5 weekends lol). I am slow- I’m a newer guy- but I’m within 8 seconds of the race leader on lap times and I’m 31 mph slower through a corner according to the data. I think it has some wins in it with the right driver with this current set up.
Included stuff- a few spares- 8 Hoosier wheels with take offs on them. Good for rolling the car around on- but not good for turning 90mph in a hairpin.
There is a spare 1200 motor I bought I’ll throw in the deal for you to get rebuilt to make this car run again. I will throw a complete exhaust in- some modification will need to be done to make it fit. As well as a clutch disk and a pressure plate. An oil cooler. Just some odds and ends to get you started on your road to fame and depleted fortune. Spare intake. Nothing fancy. I think I have a spare coil somewhere you can have as well. Spare steering wheel. We will get you some spares up. I even have a torque multiplier tool I’ll throw in for you. I have some air tools as well you’re welcome to take with you. And a feral cat if you want her. Anyways- back to the ad.
Please reach via a message on here to see the car.
With that being said-
$3500 for all this as a roller that can be on track for under $7000 dollars with motor rebuild and tires.
Prefer a cash deal. But if you can’t pay cash- shoot me your plan- and I’ll see what we can do.
Thank you guys!
