Supporting front of engine
I noticed that it seems common NOT to support the front of the VW engine when mounting in a Vee.............. but rather to let it hang off the 4 bellhousing bolts.
Does anyone add a front support to the engine ?
It seems like it might be a good idea to help dampen the bouncing of the engine as it hangs off the bellhousing.
Is there any reason this may be a bad idea, from an engineering perspective?
TIA............. Gary
Formula Vee front engine mount
Quote:
Originally Posted by
Gary Slahor
Hello Gary,
I designed a Vee back in 1981 that had a engine mount that allowed fore-aft movement but rigid in vertical movement. The fore-aft decoupling was to eliminate the difference in thermal expansion between the magnesium engine case and the steel chassis members. I recollect a relative movement of approx 0.040” due to the differences in CTE at operating temperature. Car is still in operation now owned by Robert Neumister.
Al Gegaregian
