lola t300 f5000
hi i am looking for information regarding starter motors for the lola t300, f5000 car , i am rebuilding a pheonix single seat canam which uses mainly lola parts including the bell housing but i have no info on how or starter motor is used , we are using the 72 tooth fly wheel and 7.25 clutch , i have vaious reduction starters with 9 tooth pinion but nothing is remotely near fitting to the chevy block can any one help with photos or a starter that with fit this small flywheel
I have a friend with a Chevron B51 5-liter, and am forwarding your link to him.
Do you know the HU number? If it ran in the States back in the day, I probably saw it and know of the car.
You likely know its history, but several T300s are unknown to this fine site... just in case you’re not familiar with it:
https://www.oldracingcars.com/lola/t300/
Best of Luck.
Pheonix
I may have a bell housing made specifically for the Phoenix, it is slightly different than a normal 332 bell housing. If you have any interest, I bought it hoping to use on a 332 project.
Vince@sabinadrives.com
Starters
Check with Marc Bushman in IL. He is a starter motor guru for sure. (630) 388-8880
