8 Attachment(s)
2001 Laser Mk2.5
*** SHE GONE *** That didn't take long. Seller's regret, here we come.
Looking to upgrade housing situation - looks like the RV and FV don't make the cut...
Anyway, after all the time and effort I (and, frankly, previous owner) put into it, I'm listing it for sale. I had issue-free weekends at Autobahn, several times at Pitt Race, and Mid-Ohio. Got a P5 at Mid-Ohio in my 2nd ever race weekend, getting the CCS hard charger award for that weekend. Helps to qualify low, lol. Keeps up with the pack in a straight line, needs a faster driver for the twisty bits!!
I bought the car for 12k with a blown motor. Well, it blew the first time I started it, crankshaft pins sheared. Al Varacins took this motor and another motor I had and assembled the one that's in the car right now. To be clear, this isn't a "Varacins motor" and isn't being sold as such, but Al did assemble it, dyno it, and I've ran it 4 weekends with no problems to speak of.
I sanded down all bodywork, reinforced thinner areas/cracks with cloth/resin, and applied white paint with red vinyl. I also painted the inside of the body white, because the prior red paint was rubbing off on my white suit. Don't get a white racing suit. IMO the prettiest of all modern Formula Vees. I'm 180lbs and a little over 6' tall and fit pretty well.
Here's the full build list:
Chassis Identification Number 49
Log book Number 18-860
New Speed Sport Engineering Disk Brakes Package
New Wilwood 4 piston calipers
New ¾” Wilwood front and rear master cylinders
Powder coated front beam
New Front Spring Pack
New Ride height adjuster
New Brake Bias Adjuster
New Stainless Steel Brake, Gas and Clutch Pedals
New Front Suspension Performance Heim Joints
AIM Evo 4 and Mychron 3 Dash Data Acquisition system
Throttle Position sensor, New Brake Pressure Sensor, Steering angle Sensor (New Belt), Oil Pressure Sensor, Oil Temperature Sensor, GPS Mapping and Lap Times (All wires checked and replaced if showing wear) USB Download cable to race studio 2
EGT sensor and lead (Not installed yet)
Wired in AIM Transponder
New Recessed Dash and Switches
Fully Charged Fire suppression system
New custom Fuel Safe fuel cell
New Impact safety belts (Cam Lock Style quick release)
Four race weekends on engine
National level Intake
National Level Veetek Heads
National Level Quixote Carburetor
New Roxanne 2021 headers
Freshly Rebuilt Short Box (Currently Installed)
Lybarger long box (Spare)
New Shock Offset mounts
Carbon Fiber Wind screen/ deflector
Momo Formula Steering wheel
New Penske 7120 single adjustable Front Shocks -setup by Stephen Horn from Penske
New Penske 8300 Rear Shock with remote adjustable reservoir - Valving: A & D -setup by Stephen Horn from Penske
140lbs 2.25” Rear Spring
New Rear Nylon insert Heim joints
New in car radio system (Excludes Motorola radio)
Spare set of Chrome Rims
New Set of Rain Tires (On Chrome Rims)
Head Cooling Air deflectors
Intake Air Scoop and bottom seal for K&N Air Cleaner
New Throttle Cable, Springs and Mount
New white paint with red vinyl
Body work is used, but in very good condition. Went through and reinforced stress point with fiberglass before paint. Body worked is also fully painted on the inside
New Redline Lightweight Transmission oil (For open wheel cars)
New Royal Purple XPR 10W-40 Racing Oil
New NGK Spark Plugs
$12,500. A little room to haggle but I've considered raffling the car off as well. Motivated to sell but not to take a bigger loss than I already have, haha. I'll be pretty flexible with transport. If you're within a 12 hour drive I can meet you halfway. Beyond that and we'd have to work something out.
Hoping Lazer the Kid bought it..................
Edit: Mystery solved ;-)
Beautiful car.
