Right front brake sticking, inconsistently (Avalanche 2500)
Pals,
I have a 2002 Chevrolet Avalanche 2500 and the brakes have not been great forever, like, often pulling to one side suddenly.
The most obvious culprit is a sticking caliper, but I've replaced them, along with rotors, pads and fluid. That helped for a while, but a few months later the problem is back. When I drive I get a slight pull to the right (even without applying the brakes), a hot front hub, can smell brakes, etc. Luckily it's usually only a slight drag, not keeping me from getting somewhere, but at times has been closer to locked up.
It's possible I got a poorly rebuilt caliper from the auto parts store. I plan to remove the caliper and work the pistons in and out to see if any are sticking.
Could it be a brake line, or master cylinder? It seems odd that only one front brake is affected.
Any other suggestions? Thanks in advance.
