Sold
Sold
Sold
Sold
Sold
Package delivered today, Mike. At your pace.
Package received and in the Cryo chamber as I type.
Looks to be 11hours and 41 minutes left in segment #2 of 8 segments. https://uploads.tapatalk-cdn.com/202...5be85309c7.jpg
Sold
PM sent
Sold
Sold
Agony of running it? Sounds like just the type of car for me.
Sold
I was being a smart guy. I read the description and it seems like a great car. If I wan't involved in a handful of other projects, my vintage DSR being one, I would pick this up in a heart beat.
Sold
I'm trying to ignore this thread. ;)
With Current rules, couldn't this car run as a P2?
Tony
Assuming that all other P2 requirements being satisfied, it would seem to fit under Line B.5 in the P2 Engine Table but the engine cannot be modified.
That's interesting. Honestly, I've not picked up a SCCA GCR in about 10 years and have no intention on picking one up in the future so I have no clue. All my customers have switched over to Vintage/Historic racing.
What I do know about this car since I'm the only person that's ever maintained it is that it's possibly easier to maintain than a Club Ford and just as reliable.
If you have not looked at a GCR in 10 years, then you probably missed seeing any of the P1/P2 changes when CSR/DSR were replaced. Since this car was a CSR/DSR, then the basic construction/safety is probably acceptable. Will attempt to summarize some of the simple rules for P2 that I had to consider to convert my old WF1 from P1 to P2.
Engine rules vary but your engine fits (line B.5) but the engine cannot be modified. Throttle Body Restrictor size is 33mm and the min weight w/driver is 1185. Although you say this is a George Dean engine, you do not say whether it is modified or not.
Rear Wing is limited to fitting within a 6x12 box which amounts to a 13.25 chord. Can be either single or with a flap. Wing end plates are limited to fitting within a 14" square. From the pictures, it would seem that the wing is OK. Did not see any wing end plates.
Rear diffuser cannot start its upsweep until the leading edge of the rear tires. Cannot see what your diffuser configuration is like from the picture. I used some tunnel blockers to transform the 2006 WF1 style diffuser to meet this requirement.
Brakes lights are no longer required. Rain lights are required.
There is a Table 1 (Spec Line Cars) section for some older cars (AMAC, Cheetah, etc). Although this car is not mentioned, it would seem to be similar to those cars. It might be a simple matter to get it included. David Arken could comment better on that. If it were classified as a spec line car, the min weight would be reduced.
Edit post
PM sent
I know that I need new glasses, but I haven't been able to find the asking price in the listing. Thanks !
Where did this end up?
Mike;
Axles on the way for Cryo/REM.
Well Rick, I'm sitting in the middle of the paddock at Sebring right now and then a few days next week on the gulf catching fish. I'll be in the shop on the 4th. All deliveries are being dropped at a neighboring business so it shouldn't be a problem while I'm gone.
Mike;
I had an issue in the garden today, so I did not get them out. On the way when you get home.
Found a new home in Ohio.
