Question on wheels/rims for Stohr WF1
I have a Stohr WF1 (older one that went through full upgrade/conversion) and looking to get a third set of rims for rain tires. Had a few questions to ask so figured i'd try our forum knowing i'd get some answers back.
1. Any good sources you can recommend for used rims/wheel sets?
2. Best places to turn to for new set of rims/wheels?
3. I know there are some manufacturer options out there, what are the recommended manufacturers and why?
4. Having not purchased rains yet for this car, wanted to confirm if sizing was typically kept in line with dry tires (car has Hoosiers (front = 20.0 x 7.5 - 13) and rear (22.5 x 10.0 - 13))
Bill
wheels and rims for Stohr
Quote:
Originally Posted by
lowside67
Hi there,
I don't do any autocross with this car - my preferred venues are hillclimb and time trials.
The Pirellis are ultra soft UK hillclimb tires and wouldn't be appropriate for anything road racing.
However, the Hankooks are literally the spec F4 USA championship tire for the Ligier F4 cars - they run the same sized wheels/tires we do and are the same weight. They are my tire for time attack events where I will be on track for up to 20 minutes at a time.
I run a normal road race alignment and setup given that the time attack events take place on tracks such as Mission, the Ridge, etc.
Cheers,
Mark
Mark
Would be interesting what your before and after run tire temps and tire pressures are on both the Hillclimb tires and time trial tires. I don't know the total time for your hill climbs but doubt if it generates much heat in the tire to really get it to work as well as in the time trials events. Again durometer readings for both tire sets would be useful both before and after a run.
I can expect 6-7 lb. increase in tire pressure for a 30 minute race, due to heat generation . In a 20 minute time trial you should be able to get up to heat. In short events with little heat generation in the tires, tire pressure IMO would be critical.
Racerex1
