10 Attachment(s)
1969 Macon MR 7 VFF or HFF, s/n 107 with tons of spares
1969 Macon MR7 for sale. Built 04/08/1969 Monoposto legal. Health issues have greatly reduced my event participation over the last two years. Last raced at Indy 2019 with rebuilt 711M block with one event. Featuring strong running motor with 10/10 race prepped crank, Swain coated bearings, Scat rods, Carillo Swain coated pistons, balanced, Ivey cast iron head/ prepped by Ivey in(2019) ARP hardware throughout, Quartermaster 7.25 clutch. rebuilt 5 port oil pump.
The Macon is extremely dependable, only 1 DNS in 5 years. Comes with SVRA and VRG log books dating from the 90's. The car is not a trailer queen but it has been maintained professionally and personally the last 5 years.
Hard wired transponder
Re valved steel body shocks by Anze Suspension in 2018
Weller steel wheels, 2 sets
Varley Red top battery 2019 and Varley battery charger
Schroth FIA Formula belts date code 2023
Axle savers and new donuts fall of 2018
Tilton Super starter
SPARES included in the sale include but are not limited to:
Complete spare motor with 0 hours, 2737 block Std/Std Ford crank, balanced rotating assembly,Swain coated bearings, Ford race prepped rods, built using Jake's book. Has a national cast iron head stamped BL028, lightened flywheel with new Tilton 7.25 clutch. Complete carb to clutch.
13 sets of gears, 17 total sets including those in the car
7 dog rings
New rear upright, never drilled or fit
Steering rack
New Front spindle
New motor mount, never drilled.
Second set of Weller wheels
Set of new donuts
2 sets of new ignition wires
32/36 race prepped carb
10/10 FoMoCo crank
2 Working starters
New Petronix II igniters (2)
New Petronix coils (2)
New Slave cylinder
Spare 711M block needs to be re sleeved
Prepped MK8/9 transmission case with annular throw out assembled
Enough track spares to keep you running for a couple of years (plugs, throttle cable, distributors, fuel pump, water pump, gaskets, Weber parts)
I have tons of pictures if you're interested in seeing more than what is included below. I can be reached at 631-834-4884. rslittle13@gmail.com
Thanks for looking.
$23,500
this is a very nice looking machine !
i got to drive one at Nelson Ledges on a half damp track with standing puddles (ages ago)
using only three gears i matched my best times in my Hawke DL 2A
that car was owned and modified by Dan Pyanowski (a lifetime friend)
he coulda, shoulda been an INDY or F1 engineer !
ANYWAY this could be a GREAT CAR !
