-SOLD-Nova/KBS F600 for sale
!!!! SOLD!!!!! Listing my Nova/KBS Suzuki powered car for sale. This is basically a carbon copy of the yellow car that placed second at the Runoffs in 2014 @ Laguna and 2015 @ Daytona. It went through a complete ground up rebuild in 2016 with every component on the car replaced. No expense was spared with the rebuild and it really shows in the fit and finish of this car. I won the 2016 ARRC Championship with this car and finished 2nd at the Mid-Ohio super tour Major in 2017. The car is ready to win some more with a different driver.
http://www.apexspeed.com/forums/atta...id=75804&stc=1This car will fit any size driver comfortably as the cockpit has been widened. There are zero issues with this car, the engine is very strong and runs perfectly. The suspension is extremely adjustable and handles great. Perfect water and oil temps even when its very HOT outside.
Car hits minimum weight hot off the track with 3/4 of a gallon of fuel left in the tank and a 180 lb. driver
-Eric :checkered:
(810-441-6435
emcree46@yahoo.com
Engine
-2007 Suzuki GSXR-4 race weekends
-Moon billet oil pan
-Moon heat exchanger block off
-Power commander 5 with AutoTune module.
-Flashed ECU
-Piontek engineering custom header with 4 into 1 Merge collector
-Straight pipe exhaust with (2) O2 bungs
-Header ceramic coated inside and out for heat retention
-Coast Fab stainless muffler freshly packed with (2) O2 bungs
-NGK iridium spark plugs
-Holley fuel pickup sock, new design (no fuel surge tank necessary)
-Walbro HP fuel pump
-MagnaFlow FP regulator
-Antigravity battery (weighs 12oz)
-Cleaned and matched fuel injectors
-Engine Ice coolant
-Piontek custom airbox with painted intake
-Silicone radiator hoses
-Aircraft fire sleeve hose sheath in critical areas throughout
-Custom Zeroclearance double firewall
-SS/ceramic insulation engine scatter blanket
-Dry break quick disconnect fuel fittings to empty fuel cell quickly and easily
Chassis/Suspension
-Bead blasted and powder coated satin black frame
-.063" 6061 aluminum bonded and countersunk riveted belly pan
-UHMW rub strips on underside of car
-NOVARACE front and rear suspension components (new matched rubber pucks and friction washers)
-All front control arms powder coated satin black
-New Ceramic front wheel bearings
-New front hubs
-New front rotors
- Aurora and QC-1 rod ends
-All new AN hardware throughout entire car
-Satin black powder coated Douglas aluminum wheels
-New Wilwood DynaPro front calipers (Very rigid)
-New Willwood lightweight compact master cylinders
-New Willwood pads F&R
-New Kevlar reinforced braided brake lines
-Custom CNC scalloped and drilled rear brake rotor
-Piontek aluminum brake pedal
-Custom made throttle, clutch, and shifter cables
-Custom Aluminum fuel cell enclosure
- Aluminum cockpit enclosure panels
-NovaRace/Piontek 50mm rear axle with Heavy duty uprights & bearings
-New EK ZVX3 530 Gold chains
-Martin hardened steel primary gears
-New jack shaft bearings
-Gun drilled jackshaft for reduced weight
-Rebel gear split rear aluminum sprocket
-Aluminum radiator and Oil cooler air ducting
-Alpha steering wheel
-Mark Williams QD steering wheel hub
-New QRE steering rack
Safety
-New Firebottle fire suppression system with 2 discharge nozzles (cockpit and header/oilpan areas)
-New for 2017 Racequip Hans style belts
-Custom made 5.5 gallon Fuelsafe cell
-SCCA approved fuel sample port
-LED Rain light
-Carbon x covered drivers seat (6'2" 190 lb driver)
Body
-Leading edge Carbon fiber diffuser
-New paint in 2016 -Ford Race red w/2K clear
-Carbon fiber rear diffuser plates
-TR-1 Sports car nose with UHMW splitters
-TR-1 Body sanded down and lightened as much as possible
Spares included in sale with car
-Preform Resources rear diffuser with UHMW rub strips
-Complete set of spare Douglas wheels with tires (black)
-Spare formula style nose (painted but never used)
-Many spare Aero tubing front control arms (new and powder coated)
-Many spare suspension push rods
-Spare gun drilled jack shaft
-1 spare chain
-2 spare front hubs with new bearings
-4 spare front rotors
-2 spare front master cylinders
-2 spare front brake calipers
-Eric :checkered:
emcree46@yahoo.com
Extra Options available
Data
-AIM MXL2 Data system with oil pressure, oil temp, water temp, fuel pressure, GPS sensors
-AIM wired into K-line ECM for all engine parameters including manifold pressure and throttle position
-4 custom EGT sensors, one in each exhaust primary
-AIM 4 port Data Hub
-AIM 4 port TC expansion
-AIM 4 port Channel expansion
-AIM inline DC Power filter $3000 for complete data package
Engines
- #1 Very clean 2007 Suzuki engine fresh off a bike 3000mi
-Never been in the car- Great compression and leakdown numbers
-Comes with uncut harness, Stock airbox, and throttle bodies $1400
- #2 2007 Suzuki engine with 7 race weekends
-Piontek oil pan and block off plate
-Comes with throttle bodies and stock airbox
-Great compression and leakdown numbers $1500
