Does anyone know the part number (and/or brand) for the throttle position sensor used on zetecs?
Motec, Talk to Dave at Veracity he set me up with a couple.
I looked back at my notes, I think it says M 518-3...I think...I don't have my glasses...
Call Sandy or Eric @Q silver the new Penney & Gilles is a bit pricey but will be the last one you will buy.
Thanks Guys,
I'm going with the Penney & Gilles.
Turns out the stock ones don't do well in the wet (the reason I need one).
Gavin,
Is this the one you bought?
http://www.cw-industrialgroup.com/Pr...-TPS280DP.aspx
Can anyone suggest what is a good replacement TPS Zetec sensor?
The one QS now supplies, and is on my car, is supposed to be waterproof.
What connector are you using on the harness side? I believe those that have updated to the QS/Penny & Giles sensor moved to a mil spec connector, but the original harness used a Bosch (EV1, I believe) connector and an off the shelf European Ford TPS sensor. If you need that Ford sensor I have the PN. I am still using the original sensor and had to order a bunch for spares a few years ago. There's a ton of very similar sensors but all with minor differences and I only found one that works (can't find the PN in my notes but could look at the packaging at home).
I still have the standard automotive style connector. I have several engines so if I switch to a sensor with a mil-spec connector I would have to make an adapter or switch the sensor all of the engines. I'm only looking for a spare at this point, so the original Ford style part number would be good. But I'll also contact Eric for info on the Penny & Giles version.
Thanks!
Ford PN 88WF9B989
Google was the only help.
If I remember I found several thru ebay and stocked up that way instead of buying them thru alibaba, etc. They seem to be very common elsewhere in the world.
