Originally Posted by
DaveW
:D
I don't understand what you said - the side that faces the clutch disk IS the side that faces the flywheel...;)
Anyway I think I understand what you did - flipped steel part of the PP over. So I am guessing that this is a 2-piece PP, the aluminum triangular cross-section fulcrum piece, and a flat ~3/16" thick steel PP.
So I think the reason flipping it worked is that the "flat" PP was warped (maybe 1/16" in to out) from heat into a shape similar to a Bellville spring.
I've had that warpage issue myself.
