FSV 1800 to 1600 compatibility questions
To: ApexSpeed readers and knowers of all things important.
The '78 Lola T-620 FSV which I'm restoring actually had an 1800 in it and ran SCCA and RMVR as a FA in accordance with both club's rules. I was willing to just go thru the engine, refresh as needed and stick with the 1800. But long story short (and sad), the engine was pretty much crap, only being able to salvage the block and head, both of which still needed some attention. Arrrgh!
Anyway, I was willing to do that. But, I'd really rather put it back to the original 1600 for a proper original FSV configuration. And, it turns out I might even have a lead on a nice 1600 FSV engine out of a Ralt RT-5.
But before considering going back to 1600, and not knowledgeable at all about these power plants, I'm wondering about the dimensional (or other) differences between 1600 and 1800 engines besides displacement:
- Are motor mount bosses the same?
- Is the bolt pattern for the Hewland adapter to the block the same?
- Do both use the same Hewland adapter? The one on the 1800 was about 1" thick (I'm guessing from memory about it's thickness.)?
- Is the bolt pattern on the crank for the flywheel the same?
- Did they use basically the same flywheel and starter arrangement? (the starter on the 1800 mounted to the adapter.)
- Are there any other external dimensions that would create issues if reverting to a 1600 FSV engine?
- If the bolt pattern for the flywheel is the same, can both use the same flywheel.
- Are the intake and exhaust ports on the head the same?
In general, what are the issues of going back to the 1600 power plant which I need to consider.
Oh, if any of you have a good complete 1600 you'd be interested in selling, I might consider it providing answers to the above mean minimum of brain damage to revert back to a proper 1600.
Thanks for any input or advice.
Respond here or direct to r.alder@earthlink.net or 303-981-6364
