Anyone familiar w/ the Italian ACROBALEO Formula Car?
Hi everyone, Just had a few questions to ask about a certain Italian Formula 1000 car I was looking at.
They are called Arcobaleno's, just seeing if anyone had any reviews, experience, opinions, etc... about this Company or open-wheel race car, would there be easily available parts (other than the engine). [FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]
Thank you for your time, [/FONT]
Here are the tech details:
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular][/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]TECHNICAL DETAILS[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]CHASSIS: Cro-moly tube spaceframe, with aluminium panels riveted and glued to frame.[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]SUSPENSIONS: Front suspension configuration consists of two upright coils over shocks with pull-rods. The rear suspension design consists of two horizontal coils over shocks with push rods. Both front and back have 12 adjustment settings.[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]BRAKES: (2) Front discs 10.63" (270 mm) diameter by .45" (11.5 mm) thick, single rear ventilated disc 9.45" (240 mm) diameter by .85" (21.5 mm) thick, 4 pistons calipers.[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]ENGINE: YAMAHA YZF IOOO cc, 4 cylinder, 4 stroke, 20 valves. Forced lubrication system with oil cooler. Water-cooled. 1.5” (38 mm) MIKUNI carburetors.[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]GEARBOX: 5 speed sequential.[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]POWERTRAIN: Chain with sprockets + reverse gear (Arcobaleno), 4 available different rear sprocket ratios for maximum velocity from 165 to 230 Km/h. (Ratio: 13/42, 14/38, 14/40, 17/39)[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]MAXIMUM POWER: 140 HP at 10,000 rpm.[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]ELECTRONIC IGNITION: Rainbow Spark by Pegaso, with a programmable intrusion-proof rpm limiting device. (8,000 to 12,000 rpm)[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]CAR CHARACTERISTICS:[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]WHEEL BASE: 88.60' (2250 mm)
FRONT TRACK: 55.12' (1400 mm)
REAR TRACK: 53.35' (1355 mm)
MIN GROUND CLEARANCE: 1.77' (45 mm)
MAX HEIGHT: 43.31' (111O mm)
OVERALL LENGTH: 139.76' (3550 mm)
OVERALL WIDTH: 63.00' (1600 mm)
WEIGHT: 815.73 lb (370 Kg)
RIMS: magnesium 6.5' x 1'(165 mm x 25 mm) front, 8' X 13' (203 mm x 330 mm) rear
TIRES: AVON 6.0' x 19.5' x 13' front (152 mm x 495 mm x 330 mm) front 8' X 19.5' X 13' (152 mm x 495 mm x 330 mm) rear
ADJUSTABLE WINGS: Front and rear wings already low velocity operation.[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Thank you for your time,
[/FONT]
swap engine to R1 and race it
If the price is right, drop a more current Yamaha YZF R1 motor in it and go run it. Anything 2005 and newer will do and can be had for $1000 in todays market. might want to swap out the speedway size tires for some 8's and 10's though.
