Gopro video camera aerodynamics
I like the video and cost of the GoPro HD video camera but don't want to attach something to the rollbar that will have anymore than a very minor/unimportant affect on aerodynamics. I'd like to get some input on this before making a decision on the camera.
Are the videos on your site taken with this camera?
Yes, they are. All attached with the small stick-on mount.
attach a GoPro to a Swift DB-1
Does anyone know how to attach a GoPro to a Swift DB-1? The roll bar is 13/8ths, and very little is exposed, with tight spacing otherwise. My machinist friend is busy right now, so I'm a bit stuck.---Jim
video camera mount for a DB1-over the roll bar
This is how I mounted my Contour cam on my DB1. I used .050" Alum for the base. Be aware that this is close to the coil and HT wires, therefore there is some EM interference. But the view is terrific.
dave
Attachment 24569
Attachment 24570
Attachment 24571
Attachment 24572
GoPro Mounting Issues - aka Mounting Failures
I just pulled up this post because I am now in the market for a new cam. I was heading down the front straight at BHF last weekend when the mounting case on my GoPro failed. The GoPro is secured by a compression system, and if you don't tighten it hard enough, the camera will move (point straight in the air). The problem is that if you over tighten it, the plastic will crack and fail under high speed/wind conditions.
Thankfully, no one was hurt by my flying cam, but the stewards were FAR from pleased (it DID meet SCCA regulations before failing - under 8oz). They actually didn't allow a FV competitor to use his because they were concerned about the integrity of the mounting. Coincidentally, at the previous event at BHF (Fall Sprints) a S2000 had the exact same thing happen to him (same place). Thankfully the shards of the case didn't puncture my tire when I hit it. Anybody else had the same issue? Also, the previous 5 track sessions it had shut off, and the files were corrupt. Why am I paying so much if the thing isn't working all the time?
I did here some people talk about putting a soft washer in the GoPro system to make it grip better without tightening so hard.
I'm torn between the POV 1.5 (seems the safe choice), another GoPro, and the Contour HD. My biggest concern is that I have belted in my dad for the first time in 28yrs, and wanted to capture that moment, and now it's gone. I also had my brother in the car for his drivers school and that video was also corrupted.
What do we think? POV? Where do I get a good roll bar mount for my RF'97?? (hopefully for not an arm and a leg - this is already cutting into my tire budget - aka my one set of stickers this year....)
Go ApexSpeed! Best forum ever.
-Patrick
Race-Technology Video 4 Quality?
Anybody have any formula car experience with the Race-Technology Video 4 system in regard to video quality, reliability, etc.? The Video 4 has been available for over a year I think.
I'm considering getting a Race-Technology DL-1 with somebody's camera versus the brand new Video 4 with GPS and sensor inputs to replace my current GoPro and MaxQData "video" and "DA". Cost starting from scratch seems about the same.
This is an autocross application so I have no need for a real time electronic dash and don't need more sensor inputs than the new Video 4 system provides. In fact, it appears that my Stack recording tach which can replay whole runs is the best way to get quick rpm info (not just peaks) between runs.
Thanks!
Dick
85 VD
CM 85
