Caliper Piston Size restriction
Is the following part of FB/F1000 rules involving Caliper Piston size valid?
J. Brakes
Unrestricted, except:
1. All pistons in a given caliper must be of the same size. Calipers
must be ferrous or aluminum alloy.
http://www.formula1000.com/
If so, what is the reasoning behind it?
Has anyone taken into consideration the cost of the brake pads when making that rule up?
With more even pad pressure, there will be more even pad wear which results in longer pad life...hence, after replacing pads a few times, the extra initial caliper cost will eventually be made up in lower pad costs over the lifetime on the car.
