This is good news. Does anyone know who the fuel supplier is (or will be) for R-A at the Sprints? And what is this 112-octane fuel called?
Thanks to all those who voiced their opinion on the matter. :cool:
I suspect its Sunoco 112 leaded fuel (currently spec'd by NASCAR)
Road America does indeed use Sunoco, or atleast has for the last 4 years that i have been there. Pumps are credit card access.
We all need to thank Rob Klein at Liberty Motorsports for getting this approved.
Our wallets thank you Rob!! :D:D:D
Just talked to Scott Sanda and there was a typo, the spec fuel will be Sunoco 110 leaded.
Rob
Liberty Motorsports
Well forget it then...I'm using C44 ;) :D
Where did this information come from?
How are they enforcing it?
Are we lucky enough to have it to apply to FF also?
Same system that was used at the Runoffs
Brad, I think the 2006 Taylor Extreme TD06 will be fast on Pond Water
1. June Sprints suppsQuote:
Originally Posted by mblanc
2. fuel tests just like the Runoffs
3. It was mentioned only for FC, since FC competitors asked for it and wrote letters of support for it.
I don't know if FF could get this instituted or not.
We use AVE Gas here, its between 105 and 120 octane, depending how fresh it is, the Formula Toyotas were useing unleaded 96 fuel, and Motor Sport NZ is trying to get us to use unleaded, but that would lead to a lot of problems I think, you don't see aircraft useing it do you!
Roger
Quote:
Originally Posted by Liberty Motor Sports
My budget sure would appreciate it running on pond water....
Good Morning,
I just wanted to make everyone aware that there is an error in the Supps for the Sprints.
The Supps say 112 octane, but the track really has 110 octane sunoco blue. We will be correcting the Supps at the event to match reality.
The track also used to have 100 octane unleaded, but decided to go with 98 this year, so we are playing catch up on a number of things.
Best regards,
Scott
RE, Chicago
Thanks for the official correction Scott! We'd also like to thank the work you and Rob Klein did in getting this done. It's brings the "Have's and Have Not's" closer together in competition.
Uhhhhhhhhh.... :confused:Quote:
Originally Posted by scott sanda
Sunoco Blue IS 112 octane. Sunoco purple is 110. So which is it?
EDIT: I emailed Scott, and he replied that he is going to clarify this.
Roger (NZ) the higest octane AVE Gas we can get here is 100 Octane -Low Lead. The low lead part is not to accurate as it still has quite a lot of lead in it. It works good up to about 10.5 to 1 compression. If we could get 105-120 Octane AVE Gas here it would be nice!:D
AVGAS octane does not directly correlate to MOGAS AKI or octane. Different testing methods.
And there is a move towards 96UL (Unleaded) for aviation gasoline in the US (and Europe). Most light aircraft were originally designed to run on either 80/87 (red) or 91/96 (blue), not many light aircraft needed 100/130 (green). The 91/96 formula was replaced with the 100LL (also blue), and the 100LL eventually replaced the 100/130 (green) also. The 96 UL is 100LL without the lead.
115/145 (purple) was used by the military and airlines for the high HP engines. Someone makes a batch each year for the Reno air races.
We confirmed that the fuel is 110 Octane at RA this past weekend.
Scott
FYI
Sunoco 110 (aka camII) is purple
Road America has had it at their pumps for 20 years
Augie
Thanks, Scott. Sunoco 110 (purple) it is!Quote:
Cam2, one of the best smells in the world. :D
Well, this went fantastically! Where do I sign up to have track fuel for every National event? How do we get this again for next year's Sprints? Does anyone know if they tested fuel for those who were impounded?
AFAIK, they just tested Niki (1st place). My fuel didn't get tested.
We were pitted at the impound area, during practice and qualifying they impounded 3 cars each session at random. My first thought was that OH OH somebody was in trouble but then seen them taking fuel samples. I don't know who was checked.
Rob
Rob, what did you do to get this pushed through and in the supps? A couple of us FF guys thought a gentlemans agreement was sufficient...wrong. Just curious if it was a big deal.
Thanks, and great party by the way.
Cliff, I will email you or call you tomorrow to explain the process.
Rob
You guys in the US can't change your ECU maps??? Is that correct? How did the engines take the 110 if it was mapped for 99?
I would be interested to hear if anyone felt any real performance difference?
I have been thinking of changing fuel but been told you need to play with the advancment and maps to work well which could be a pain
I was disappointed to see that there weren't any Zetec cars in the field. Only Pintos.Quote:
Originally Posted by redracer57
Keith,Quote:
Originally Posted by Keith Carter
Couldn't make the Sprints, but I'm planning on the Cat.
