4 Attachment(s)
Build Thread: 97 Van Diemen
Figured I should start a build thread to get advice and have people check my work. After going to Waterford Hills (which was wonderful) I ended up buying Cade Wilson's '97 (original owner was Justin Pritchard, will attach a photo of the original car as well).
I had him fit the new aluminum belly pan for me, so I just got it to my garage this weekend. I've spent the past few days cleaning the chassis and taking measurements (hoping to put the chassis into Solidworks and use photogrammetry to get the body in Solidworks as well) while I wait for my suspension bolt kit + owner's manual to arrive from Primus. At the moment I've got a few quick questions about things I saw while cleaning.
1. Some of the rod ends (on the front suspension in particular) are definitely in need of replacement, but most look to be in good shape. Do I need to/should I replace the rod ends anyway, or would just the rod end bearings suffice?
2. I have the inverse problem of everyone, and might be a bit small for the '97. I've attached a photo of my vertical visibility from the cockpit, should I try to get myself higher up?
3. The rear suspension has the number 297 on the upward-facing side of the a-arm. The front suspension has the number on the downward-facing side. Is this just...how it works, or is it just on upside-down?
4. A few things I noticed in the deep clean - There is a rubber ring sitting on the steering rack, where could it have come from? Similarly, the gasket on the top of the swirl pot appears to be flaking, does it have a dedicated gasket or should I make my own?
Will post again once I get the suspension bolts on with photos so you guys can check my work. Excited to see you on the track!
https://www.apexspeed.com/forums/att...d=100460&stc=1https://www.apexspeed.com/forums/att...d=100459&stc=1https://www.apexspeed.com/forums/att...d=100458&stc=1https://www.apexspeed.com/forums/att...d=100457&stc=1
