Thoughts on New Seat for RF81 FF
I want to do something for seating in my RF81 that I run I’ve been running in vintage events the last couple of years. I believe it has the original fiberglass seat in in. A few things about the existing set-up:
- I set higher than I would like. It doesn’t help that I’m suited up, I’m a bit wider than the seat, and feel like I don’t get quite to the bottom
- It must have a replacement fuel cell can in it, as at some point someone added a side bracket to raise the seat up a bit (see pics). If you take the bracket off and try using the original seat slots the seat hits the fuel cell can
- The belt bar appears to be a replacement. It’s higher than original with closer than original mounting holes presumably for a HANS
- If I test sit in the car with my back directly on the cell, it “oil cans” quite a bit, which concerns me a bit in terms of a seat insert
- The body of the car is about 12” tall on top of the top frame rail
So a few questions:
1. What’s the latest thoughts on the various options on the market for the DIY guy?
2. What size kit do I need? I’m about 5’10” and 183 (but trying to drop a few) lbs
3. Thoughts on the oil canning issue? Will the seat provide enough “structure” to span the cell so this isn’t an issue?
4. I’d like the seat to extend up past the top frame rail for more lateral stability. Advice on providing a temp “backer” to contain the seat in this area?
Open to any advice at this point.
Thanks!
https://i.postimg.cc/fWYN2mYX/IMG-6167.jpg
https://i.postimg.cc/wM5Y1Y9F/IMG-6168.jpg
https://i.postimg.cc/MKD8xwPp/IMG-6169.jpg
https://i.postimg.cc/KvFydj5W/IMG-6170.jpg
https://i.postimg.cc/SRbpQxbJ/IMG-6173.jpg
never run a car with a fiberglass seat
Great advise. Been there (HP Sprite), broke the ribs.
