    Montreal, QC, Canada
    Post 97 Van Diemen Honda F1600 for sale
    Hewland LD 200 gearbox
    2-way Penske shocks
    Brake balance bias knob in cockpit
    Adjustable front sway bar control in cockpit
    Transponder
    2023 Improvements: (“new” meaning 5 week-ends or less)
    New AIM-MXm dash logger
    New Lifeline fire system (bottle, tubes, nozzles, cable, handle)
    New TRS belts good through end 2028
    New battery
    New brake floating rotors and bolts
    Rebuilt front brake master cylinder
    New front sway bar rotating blade (to be installed)
    New throttle line
    New gearbox cover nuts and studs
    New slipping rod and U-joint for gear linkage
    Also included:
    Set of 21 gears in total + 4 clutch rings + 1 extra spacer layshaft tail
    Set of 7 Hyperco spring pairs in total
    11 Panasport wheels in total
    New extra wishbones: Left Rear lower & upper, Right Rear lower (2) & upper
    1 extra nose + 1 extra front body cover
    Fiberglass seat (for drivers below 5ft8in)
    9 used Toyo Proxes R888R tires (of which 2 rears with only 2 heat cycles) and 7 used R888
    Miscellaneous extra parts: Sway bar cockpit control; Bleeder screws; Centerlock wheel nut; Rod end.
    The car suits mostly drivers up to 5ft10in tall. Shifter has been moved forward to allow for longer arms.
    Canadian $34,500 (or US$ equivalent i.e around US $25,000 as of today)
    Based in Montreal QC, Canada
    fxlassus at gmail dot com
  2. The following 4 users liked this post:
