Home
Go Back   ApexSpeed > Off Track Forums > Coffee & Doughnuts
Reply
Thread Tools
Old March 5th, 2003, 3:06 PM   #1
Chris Lorenz
Post
I remember someone talking about this awhile ago but i could not find the old info.
opinions on 3 in 1 mill/drill/lathe
I have been looking at a 3in1 machine because of very limited space and cash. the 3 machines i am looking at are:
Harbor Fright 1299.00 FREE shipping
Shoptask 1895.00 plus shipping
Smithy 2199.00 plus shipping
the shoptask and harboir freight look exactly the same in the pictures and all of the specs are exact except for the shoptask has 2 motors and comes with a table and some extra tools.
Do you guys have any opinions?
thanks
Chris
Harbor Freight 44142-2vga
FREE SHIPPING
It's a mill, drill and a lathe all in one machine—perfect for small shops where space is limited. Built tough for non-stop everyday use and loaded with all the features you need. With 16 easily adjustable spindle speeds you can tackle almost any job.
The Drill Press with its 7/8'' capacity chuck can easily drill large holes through metals, woods and plastic. As a Milling Machine, you can take advantage of the four way power driven milling table for slotting. The Lathe features a quick change gear box for a wide range of inch/metric thread cutting.
Standard equipment includes a 5'', 3-jaw lathe chuck, JT33 taper drill chuck, two dead centers, double-end wrench, Allen wrenches and flat head screwdriver.
Mill/Drill head swivels 360°
16 spindle speeds—120 to 3000 RPM
12 power feeds
22 metric and 38 SAE threads
Thread gauge indicator
18-11/16'' x 6-1/4'' table size
62'' x 24'' x 39'' overall dimensions
Overall base size: 45-1/4" x 8-1/4"
Four hole mounting pattern: 45-1/4" x 6" on centers
640 lbs. shipping weight
Lathe Specifications:
RPM: 160 to 1360 RPM (7 steps)
Swing over bed: 17''
Cross slide travel: 7-3/4''
Tailstock travel: 3-1/8''
Distance between centers: 31-1/2''
Spindle taper: MT4
Tailstock taper: MT2
Mill/Drill specifications:
Motor: 3/4 HP, 110V, single phase
Spindle nose to table: 12''
Spindle center to column: 11-1/4''
Spindle travel: 4-1/4''
Longitudinal travel: 30''
Spindle taper: R8 with JT33 drill chuck taper
End mill capacity: 1-1/8''
Drilling capacity: 7/8''
$1299.00 Freee Shipping
SHOPTASK Gun Master
RETAIL PRICE 1895.00
Over the past 12 years, our famous 17-20
models have been the industry standard
for quality and features. For those of you
who have asked for a machine with a longer
distance between centers but with all the
same great functions of the original, we are
proud to introduce this super new design.
this great machine has the full 17"swing for
which we are famous. IN ADDITION, we
have increased the machine to a full 32"
between centers. This is the news you gun-
smiths have been waiting for. Now you can
have that home shop to make your dreams into
reality.
AS USUAL, WE HAVE LOADED THIS
MODEL WITH A TON OF STANDARD
FEATURES FOR YOUR CONVENIENCE.
CHECK OUT THE FOLLOWING LIST!
** TWIN MOTORS
** POWER LEAD SCREW AND CROSS SLIDE
**EASY ADJUST BELT TENSIONERS
**4.5" QUILL STROKE
** SWIVELING MILL HEAD
**DUAL MILL HEAD LOCKS
** PUSH BUTTON SAFETY SWITCH
**WIDE RANGE OF MILL SPEEDS
** COMPOUND TURRET TOOLPOST
|** OFFSETTING TAILSTOCK
** RAPID TRAVERSE RACK GEAR
** HALF NUT FOR THREADING
**LARGE SPINDLE TO COLUMN DISTANCE
** EXTRA LONG TAILSTOCK STROKE
**2 SPEED POWER FEED GEARBOX
PLUS
Check out the list of tools that come with
this machine- FREE!
1 5" 3 JAW CHUCK
1 2" MILL-DRILL VISE
1 COMPOUND TURRET TOOLPOST
1 STEADY REST
1 FOLLOW REST
1 FULL SET OF THREADING GEARS
1 DRILL CHUCK AND ARBOR
1 END MILL HOLDER
2 LATHE CENTERS
1 FULL SET WRENCHES FOR MACHINE
1 TAPER WEDGE
1 FEELER GAUGE SET
1 SET T BOLTS
3 CARBIDE LATHE TOOLS
3 END MILLS
1 DRAWBAR
1 MACHINE MANUAL
1 LATHE CHUCK SHIELD
1 TOOLPOST SHIELD
1 MILL/DRILL SHIELD
1 ALL STEEL BENCH WITH DRIP TRAY
SPECIFICATIONS
MACHINE 53"L, 19"W, 38" H
CRATE 55"L, 23"W,45" H
WEIGHT SHIPPING 800#, MACHINE 650#
MILL-DRILL SWIVEL 180 DEGREES
LATHE
SWING 17" OVER BED 8.5" OVER TABLE
DISTANCE BETWEEN CENTERS 32"
SPINDLE BORE 1.1"
HEADSTOCK TAPER MT4
TAILSTOCK TAPER MT3
SPINDLE SPEEDS 7 160 TO 1360 RPM
THREADING INCH 4-120 METRIC .2-6.0
CROSS SLIDE TRAVEL 8"
POWER 3/4 HP 110 VOLT
MILL
MILLHEAD TAPER MT3
MILL TABLE 6.25 x 18.75
T SLOT 7/16"
SPINDLE SPEEDS 16 120 TO 3000 RPM
QUILL DIAMETER 3.15"
QUILL TRAVEL 4.33"
DISTANCE TO TABLE 7.75 TO 12"
SPINDLE CENTER TO COLUMN 11.25"
DRILL
DRILL CHUCK 1/2"
ARBOR MT 3
DRILLING DEPTH 4.33"
WARRANTY 2 YEAR PARTS REPLACEMENT
SMITHY Granite 1220 LTD
www.smithy.com/granite1220xl.htm
Description:
Our extended capacity CNC model! The Granite1220 LTD CNC is packed with all the features of our Midas 1220 XL plus a whole lot more.
Benefits & Features:
Faster mill changeover (leave the chuck on your lathe) & greater capacity - 12" clearance between mill spindle and column.
Always turn at the right speed - our patented quick-release belt tensioners make spindle speed changes a breeze.
Cut time in half with our rapid traverse rack & pinion carriage travel.
Effortless thread cutting with fully reversing lead-screw, half-nut and threading dial.
Added rigidity, for those large mill set-ups, with dual column locks on the mill head.
Granite 1220 LTD CNC Specifications:
Machine dimensions:
42" L, 20" W, 34" H
Crate dimensions:
44" L, 23" W, 38" H
Shipping weight: 620 lb
Machine weight: 500 lb
Power: Twin, 3/4 hp lathe, 1/2 hp mill
Mill/drillhead stock swivel: 180 degrees
Calibrated dials:
leadscrew & cross-slide:
0.002"
tailstock: 0.002"
mill and drill: 0.040"
Mill:
Millhead taper: MT3
Table dimensions:
6" x 16-3/4"
T-slot width:
standard 7/16"
Speeds:
9 (315 to 2000 rpm)
Quill diamiter: 3"
Working height:
6-1/4" min., 13" max.
Quill center to lathe spindle face: 11"
Accepts end mills up to 1-1/4" in diamiter Drill:
1/2" precision chuck (up to 3/4" available)
Chuck arbor taper: MT3
Spindle to table: 6-1/4 to 13"
Cutting depth: 3.125"
Speeds:
9 (315 to 2000 rpm)
Lathe:
Swing:
12" over bed, 7" over table
Distance between centers: 20"
Spindle bore: 1.03"
Tapers: headstock MT4; tailstock MT3
Speeds:
6 (160 to 1600 rpm)
Pitches:
SAE (inches) 6 to 30 tpi, metric 0.5 to 4 mm
Travel: 20" longitudinal, 8" cross-slide
__________________
build Race Cars and Sell metal Bar Signs<a href="http://www.teamlorenz.com" target="_blank">www.teamlorenz.com</a>
Chris Lorenz is offline   Reply With Quote
Old March 5th, 2003, 3:42 PM   #2
Steve Demeter
Steve Demeter's Avatar
Post
To use one of those well, I think one has to be a superior machinist, bordering on a magician.
For one thing, they do not have any controllen downfeed of the spindle or controlled movement of the table in the vertical. This makes it hard to say take a fixed amount of material off in the milling mode.
If it was me, I would shop around for a used lathe and a Bridgeport type mill. Done right, you could get both for less than the $2100 Smithy and have real equipment.
Steve Demeter is offline   Reply With Quote
Old March 5th, 2003, 3:43 PM   #3
Dave Hopple
Dave Hopple's Avatar
Post
Chris, they have some really good lathe or mill deals here: http://www.use-enco.com
If your still looking for a 3-in-1 they have a Smithy 3-in-1 for 1,649.95 and a Enco for 849.95 download the pdf for info
http://www.use-enco.com/hotdeals/hd0303/5.pdf
Dave
Dave Hopple is offline   Reply With Quote
Old March 5th, 2003, 5:18 PM   #4
Ian McKechnie
Ian McKechnie's Avatar
Post
Also, take a look at the equipment sold by Grizzly (http://www.Grizzly.com). We got one of their combo lathe/mills a few months ago to add the capability of making metal components for our F2000 and other projects. As we have all our equipment and race car in a one car garage and a small part of the cellar, we could only get one that we had the space for. We settled of their Model G4015Z. It is not the most accurate thing on the planet, but works well and is accurate enough. As my driver, son and machinest says: "We are not makng a rocket ship, parts are parts." He had never run a metal working machine before and has had no problem operating it or devising fixturing methods. We did not need a drill, as we already have a floor standing one to go along with the hydrolic press, gas welder, Datona TIG welder, fiberglass body/wing/diffuser fab. stuff, etc., etc. Grizzly has other larger models if you need the capacity and have the space (G9729 & G4791). However, take a good look at the size and weight of the machine to make sure that it will not only fit, but that you can put it on its table or base. Ours weighes in at 500 lbs. unboxed. We had to use our engine crane with a special extension to lift it high enough to both get it off our truck and put it on the table we made.
If you procure one from another manufacturer, at least get their catalog. They have loads of accessories (you are going to need some of them) at reasonable prices. In any case, have lots of fun with it. You will be surprised as to how handy it will become, even for home defense projects.
__________________
Ian L. McKechnie (dad)
Crewchief FC 61
Ian McKechnie is offline   Reply With Quote
Old March 5th, 2003, 7:10 PM   #5
Chris Lorenz
Post
Thanks for the good info i will have to check out grizzly also. i don't have the space for seperate machines so it has to be 3 in 1 for now.
here are some pics
17-32 xmtc shoptask $1895.00 plus shipping but do have specials at around $1,600
Shoptask bridgemill eldarado (mill goes up and down) $2995.00 plus shipping sometimes on special for $2295.00
smithy Granite 1220 LTD $2,195.00 plus shipping
http://www.harborfreight.com/cpi/pho...4199/44142.gif
Harbor Fright $1,295.00 free shipping
Grizzly G4791 $2595.00 plus shipping
Grizzly G9729 $1395.00 plus shipping
__________________
Old March 5th, 2003, 8:08 PM   #6
PK
Post
I've had a Smithy 1220 XL (next step down from the Granite you mention) for about 7 years, and I'm pretty happy with it. Yes, I would prefer a 'real' mill and a 'real' lathe, but this fits my space, and allows me to do a lot of things I couldn't otherwise do. What surprised me for the first couple of years was that I used the lathe function at least 3 or 4 times as much as I did the mill/drill function.
The Granite is a useful improvement in that it can powerfeed the table in one direction when using the mill. I haven't really missed a vertical powerfeed.
The biggest limitation to accuracy are the machine rigidity and the precision of the moving parts like the table and spindle. The Smithy is only ok at best, but most of the time that is plenty good enough. From looking at the pictures, and some limited time looking at other models, I tend to think that the Smithy is at least as good as any others and better than most.
Don't forget that even with the tooling packages that typically come with the machines, you'll end up spending another $500 to $1000 on tooling and measuring equipment in the first year that you own it if you use it much.
PK is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©ApexSpeed 2000-2013
