    Sacramento
    For Sale FCC Championship Winning PFM for sale (complete sell out)
    sold
    Sacramento
    Bump -
    All still available.
    Sacramento
    All still available
    Sacramento
    Default Additional/detailed list
    Car lift - assemble/ mobile
    Mk custom platform scales
    New Tri-pod rubber boot (2)
    New Throttle cable
    New LF Flap
    New LF/RF Carbon gurneys
    New rain light
    New brake lines - LF/RF
    New APV harness
    New injector/valve harness
    New pipe mount exhaust
    New clutch cable
    Crow Seat belt set
    New lower alum nose mount
    New forward skid plate
    New tri pod bearing (2)
    Used clutch pak
    4 used brake rotors
    2 new brake rotors
    Brake pads in sets (various shape)
    New Carbon defuser mounts
    New AP master cylinder
    New output flange seal
    Used wheel hub
    Used fuel filter
    Used thermostat
    New 4 Alcon rotors
    Brake line cover
    New push rods (2)
    New toe link w/ heims
    Used input shaft
    Front bar - car has both with it
    New Goodyear rain tires (unmounted)
    9 lap Goodyear tires
    New 2 sets Goodyears on rims (mounted)
    New complete front nose
    New main plane
    Mk tech front quick Jack
    Mk tech rear swiveling quick Jack
    Mk short stands
    Mk tall stands
    Mk castor/camber gauge
    Mk tech alignment bars
    Front ride height gauge
    Read ride height gauge
    Used Borla Mufflers
    Pro pipe
    External batter pak to start car
    New wood skid plate (mid section)
    Stainless steel mid skid for weight low
    Rear gurneys aluminum
    New Oil hose
    Seat stays in car -
    Motec data -
    Motec beacon
    Motec download cables
    Spring sets for car up too 1000lb
    Misc nuts/bolts/heims/hardware
    Misc Hewland gear sets
    New dog ring
    Used dog rings
    Used hear sets R/P and input shafts
    New front upper control arm
    New front lower control arm
    New rear lower control arm
    New rear upper control arm
    New rear wood section
    More to come
    Classifieds Super License mikey's Avatar
    Liked: 559
    Sweet deal
    Sacramento
    This is a sweet deal, as mentioned above. Great car, still all for sale.
    Sacramento
    sold
