Results 1 to 25 of 25
    Burlington, Ma
    Liked: 20
    For Sale New Year Sale-ebration
    See post 23 for remaining items. Thank you.
    Lots of FV bits for sale. Will continue to add parts as time goes on.
    1. 12 FV wheels. 4 inch wide, slotted, all straight and racable. $40 each
    2. 2 Needle bearing beams bare. $200 each OBO SOLD
    3. 1 stock bushing beam (just off Bug) with torsion arms. $200
    4. 1 race prepped bushing beam with torsion arms. $200
    5. 2 race prepped manifolds. Unknown source and questionable legality. $50each SOLD
    6. 1 pair of heads that came off a good engine in search of more POWER. SOLD
    7. 12 quarts RedLine 30 WT race oil. SOLD
    6 large trunks of FV stuff including spindles, drums, backing plates, shoes...
    Will list ASAP, but ask if you need something specific.
    Everything is located in Burlington, Ma. Thank you.
    Burlington, Ma
    Liked: 20
    Heads SOLD
    Here are some more pics of the manifolds.
    More parts soon!
    Burlington, Ma
    Liked: 20
    More items.
    8. 2 front and 2 rear drums. Shoe surface in VGC. $20 each. Fronts have ball races.
    9. 2 front backing plates. Excellent condition SOLD
    10. Stock steering box. Good condition $40
    11. Sweet CNC offset shock mounts. SOLD
    12. Carrera dampers. SOLD
    13. Quick release hub. SOLD
    More to come.
    Burlington, Ma
    Liked: 20
    More items.
    14. Oil pressure sender. Analog and idiot output. SOLD
    15. Clutch slave cylinder. Used but working. SOLD
    16. Bosch blue coil. SOLD
    17. New link pin bushing set. $50
    18. New fuel pump. SOLD
    19. Rear axle bearing retainers. SOLD
    20. 5 rear axle boots. Split type. $5 each SOLD
    21. Race prep'ed carb. Think it leaked fuel at the gasket into throat. SOLD
    All parts will have shipping added to sale price.
    More to come.
    Senior Member Amon's Avatar
    Medina, Ohio
    Liked: 174
    Parker,
    I'll take the Carrera's if still available?
    Mark
    Burlington, Ma
    Liked: 20
    More items.
    22. Race preped carb. Dyno tuned but had flooding issues on track and has the jet bolt epoxied in place. $50 SOLD
    23. Tranny tail housing. Brand new. $40 SOLD
    24. Upper and lower torsion arms. Good Condition. $75
    25. Pair of preped spindles in good condition with offset bushings. $100 SOLD
    26. Right side preped spindle in good condition with offset bushings. $50
    27. Stock VW steering box. $40
    28. New TRW steering box. $75 SOLD
    29. New front wheel bearing set. Complete axle. Tapered roller. $20 SOLD
    30. 3 Mann oil filters. $5 each SOLD
    31. New velocity stack $50 SOLD
    32. New front axle nuts. Aluminum clamp type. SOLD
    33. New sway bar tube torsion arm spacers and shims. $20
    34. New distributor cap. $5
    35. New 36mm socket for rear axle nut. $5 SOLD
    36. Front drum with loaded backing plate. Good shoes. $70
    37. 2 Rear loaded backing plates. Good shoes. SOLD
    38. 2 brand new rear drums. $50 each
    39. 2 brand new front drums. $40 each SOLD
    40. 4 brand new beam needle bearings. $20 SOLD
    41. New stock front shoes. full axle. SOLD
    42. New stock rear shoes. full axle. SOLD
    43. New Mintex front shoes. full axle. $100
    44. Full axle of torsion arms. Good Condition. $130
    45. Almost new Bosch starter. $75
    46. Fox dampers with integrated offset mount. $20 SOLD
    47. Front left corner. Link pins to dust cap. $100
    48. Rear axle tube with full round boot ready to install. SOLD
    49. New aluminum valve cover set. SOLD
    Can't put up any more pics, so if interested, please e-mail or PM and I'll get them to you. Thank you.
    Staatsburg New York
    Anthony, I will take the new front drums. Are you stopping at the expo this weekend?
    Burlington, Ma
    Liked: 20
    Hey Tom. The drums are yours! Yes, I'll be there all day Saturday. Will bring them with me. Same goes for anyone else who wants these parts. SAVE ME PACKING and YOU SHIPPING! Prices will go down for anyone picking up parts at the expo. (NER annual meeting)
    Thank you,
    Killingworth, CT 06419
    Liked: 53
    Do you still have the needle bearing front axle tubes?
    I will be at the expo.
    Tom G.
    Burlington, Ma
    Liked: 20
    I have one bare needle bearing beam remaining.
    Would you like me to bring it to the expo?
    Liked: 53
    Yes please
    Burlington, Ma
    Liked: 20
    Lots of good parts left!
    Everything is OBO.
    Whoever drives to my shop to pick up their parts will leave with more than they bargained for!
    Burlington, Ma
    Liked: 20
    Also have 2 race prep'ed short blocks in unknown condition. Everything between and including the cylinders. SOLD
    Thank you,
    Burlington, Ma
    Liked: 20
    Default Lots of good parts remaining
    2. 1 stock bushing beam (just off Bug) with torsion arms. $200
    3. 1 race prepped bushing beam with torsion arms. $200
    4. 2 front and 2 rear drums. Shoe surface in VGC. $20 each. Fronts have ball races.
    5. Stock steering box. Good condition $40
    6. New link pin bushing set. $50
    7. Upper and lower torsion arms. Good Condition. $75
    8. Right side preped spindle in good condition with offset bushings. $50
    9. Stock VW steering box. $40
    10. New sway bar tube torsion arm spacers and shims. $20
    11. New distributor cap. $5
    12. Front drum with loaded backing plate. Good shoes. $70
    13. 2 brand new rear drums. $50 each SOLD
    14. New Mintex front shoes. full axle. $100
    15. Full axle of torsion arms. Good Condition. $130
    16. Almost new Bosch starter. $75
    17. Front left corner. Link pins to dust cap. $100
    See pics above.
    Thank you,
    Burlington, Ma
    Liked: 20
    Default New prices
    1. 9 FV wheels. 4 inch wide, slotted, all straight and racable. SOLD
    2. 1 stock bushing beam (just off Bug) with torsion arms. $150
    3. 2 front drums. Shoe surface in VGC. $10 each. Fronts have ball races.
    4. Stock steering box. Good condition $20
    5. New link pin bushing set. $40
    6. Upper and lower torsion arms. Good Condition. SOLD
    7. Right side preped spindle in good condition with offset bushings. SOLD
    8. Stock VW steering box. SOLD
    9. New distributor cap. $4.50
    10. Front drum with loaded backing plate. Good shoes. SOLD
    11. New Mintex front shoes. full axle. $50
    12. Full axle of torsion arms. Good Condition. $100
    13. Almost new Bosch starter. $60
    14. Front left corner. Link pins to dust cap. SOLD
    See pics above.
    Thank you,
    Burlington, Ma
    Liked: 20
    Wow, a year has gone by so that I don't even have to change the title!
    30% off everything!
    Or, $250 for everything! If you choose the everything option, you get lots of bits and pieces that I haven't bothered to list.
    No Shipping. Bring your S2000, Jetta, or Miata!
    Happy Holidays, Anthony.
    Burlington, Ma
    Liked: 20
    It's warming up!
    See post 15 and 16.
    Thank you,
    Adrian, Michigan
    Default Tires
    Hi, do you have any usable tires? Thanks, Ken
    Burlington, Ma
    Liked: 20
    I have many tires with tons of life left in them. They'd make great tiny tire swings, planters, those soft outdoor courts (probably known to cause cancer in the state of California), even a base for the perfect man cave coffee table.
    BUT, all their life would be used up rolling to Michigan so Michiganders and everyone else should drive over to pick them up.
    HEY, I'll make you a deal. Buy 9 tires for $30 each and I'll throw in the wheels that are inside them.
    Marlborough, MA
    Default Tires etc.
    Hi Parker,
    I could use a set of 4. I live in Marlborough MA so I could swing by and pick them up.
    Alan
    Worcester MA
    Hi Parker,
    Nick said I should contact you. I'm just starting out and need spares tires, gas cans, quick jack, spares, wheels etc.
    I live in Worcester MA so if I could come by and take a look at your stuff that be great.
    Burlington, Ma
    Liked: 20
    Zoom, just sold the last of the wheels. Must have lowered the price too much. I was really looking forward to holding onto those for another couple of years. NOT!
    Anyway, lots of good stuff left. $250 for everything.
    Sent you a private message, Anthony.
    Burlington, Ma
    Liked: 20
    Found more stuff that I had squirreled away.
    $300 for everything in the pics.
    Thanks, Anthony.
  25. #24
    Burlington, Ma
    Liked: 20
    $250 plus shipping for everything in the above post.
  26. #25
    Burlington, Ma
    Liked: 20
    Still have these front suspension pieces.
    Can probably have them delivered to the runoffs.
