Home
Old April 13th, 2013, 10:05 AM   #1
Edward Barnette
Edward Barnette's Avatar
Default Crossle 60 F
For Sale: Crossle 60 F, Trailer and Spares (1985) $ 12,000.00
Engine: Quicksilver with RFD aluminum head. First RFD head done for Quicksilver. Highest horsepower FF engine built by Quicksilver that year, sheet available.
Cylinders 2-4-3 same compression, # 1 five pounds less Leak test down cylinders 2-4-3 2% leak down test , # 1 5%
Petronix Igniter II, Petronix Epoxy coil and rev limiter. Spare new Igniter II, spare distributor
Spare prepped Kent 711 block, spare Fiesta stock block, spare Kent stock crankshaft 71K in a 1971 Pinto. All stock spare Kent parts such as rods.
Spare water pump, spare Corolla starter (just rebuilt), and two stock 1971 starters. Spare iron FF head not ported.
Exhaust is ceramic coated inside and out by Jet Hot, bolt on supertrapp muffler if needed and spare original exhaust. SCCA transponder included.
Transmission: Rebuilt by Taylor (12 races ago) Gearing to run all East Coast tracks (22 gear sets). Autocross fixed first (14/34) used three times.
Body: Three noses and spare side panel. Recently painted.
Suspension: Koni 8211 shocks, spare complete side of suspension, purchased new master cylinders for brakes and clutch last year and rebuilt the calipers.
The car has 16 Panasport wheels and one set is ultra light weight. Notebook with factory setup, engine setup and dealer part numbers for all suspension parts, and receipts. The two original SCCA log books.
Willans belts good to 2014.
Enclosed 1985 Pace 24 foot Trailer (low mileage) plus all hitch equipment.
Pit equipment: Twenty foot tarp, formula jack stands and jack. Many small spares from 20 years of racing.
I will not be selling parts separately, until the car has been sold, and if the seller does not want the trailer or some of the parts the pricing can be rearranged.
Ed-703-670-3170 barnett2@comcast.net
Edward Barnette is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©ApexSpeed 2000-2013
