RF94 Stack Dash anti vibration mounts and CV bolts
Anyone know where I can get the rubber antivibration mounts/studs for mounting a stack dash which screw right into the frame on an rf94. I can find the mounts but not in the size I need. I measure them as 3/16-32. Also I need to replace the cv bolts that go through the hub of the upright and attach to the cv and was wondering what specific grade bolt should be used. Thanks for any help!
__________________
Better to have raced for a day...
than been a spectator for life!
For the CV, use at least an alloy steel socket head cap screw. I prefer to use an MS20005 internal wrenching bolt with appropriate washer because I don't ever seem to find them coming loose.
Never had an problems using AN bolts for CV joints. Hewland came standard with less than that. Everything else will fail before they will.
We also stock 10/32 soft mounts for things like that.
__________________
Averill Racing Stuff, Inc. www.racing-stuff.com
248-585-9139
