December 21st, 2011, 2:02 PM
#1
New OZ Wheels and Used ICP Calipers
I have got a set of 8 & 10 OZ Wheels, brand new! 8's for $620.00 ea and 10's for $670.00 ea plus shipping.
I also found a set of used LD20 ICP Calipers that work with the .375 rotors. $80.00 ea plus shipping.
If anyone is interested please call or email me.
Thank you,
Chris Walsh
ACT / Afterburner Racecar Parts
952-882-0000 x 204
December 23rd, 2011, 10:39 AM
#2
Chris, are these the newer calipers?
December 27th, 2011, 12:33 PM
#3
Calipers
Rick,
No the ICP Calipers are used. I do have a set of AP calipers new if your interested. They are the steel ones.
Thank you,
Chris Walsh
612-581-1896 Cell
December 27th, 2011, 12:43 PM
#4
Quote:
Originally Posted by
Rick Iverson
He means are these the latest lightweight ones that we are quite familiar with, or the older ones which were not so lightweight, even though they were somewhat lighter than the LD20's.
IMO, he is not asking if they are new or used.
I assume, since you did not specify, that they are probably the later ICP's.
__________________
December 27th, 2011, 12:47 PM
#5
Calipers
Rick,
I apologize, and thank you Dave! These are not the newest ICP calipers. These are about 4 years old.
Thank you,
Chris Walsh
December 27th, 2011, 2:04 PM
#6
I guess the question should be ... how much do they weigh? thanking you in advance..
December 27th, 2011, 2:35 PM
#7
These are the latest spec ICP ld-20s.
Rick- mine sold but these are the same as the ones I had.
December 27th, 2011, 4:49 PM
#8
Are these what you have
ICP20 Leg Mount Caliper
This caliper is a lightweight and affordable alternative to the standard AP Lockheed LD20 caliper. The cast iron body (legal for Formula Ford and Formula Continental) uses a crossover bridge design to reduce weight by 63% (4.25 lbs less than an LD20) while increasing stiffness by 50%. It is designed to bolt directly in place of an LD20 caliper and use LD20 pads. Standard LD20 calipers are normally mated to 3/8" thick rotors, but a narrowed version is available for 1/4" thick rotors to save even more weight. All ICP calipers have 1.75" stainless steel pistons.
December 27th, 2011, 4:51 PM
#9
if so consider them sold [a set of 4?] ...
December 27th, 2011, 5:08 PM
#10
oops didn't mean to step on you Rick ...
December 27th, 2011, 5:19 PM
#11
Calipers
I will get their exact part numbers tomorrow on the AP and the ICP's.
Thank you,
Chris
December 27th, 2011, 5:26 PM
#12
Roger that ... between Rick [first dibs] or me you have them sold ... if they are correct...
December 28th, 2011, 9:04 AM
#13
Dave and Brian, thanks for getting this sorted out.
Jim, check your home email. Sorry about the confusion.
Chris, I'll take them. We're going to Ft. Rucker this AM, but I'll call with payment information this afternoon.
Iverson
December 28th, 2011, 9:06 AM
#14
I mis-understood, your PM it's a good deal for you ...later
December 28th, 2011, 9:16 AM
#15
Are you back in Michigan?
December 28th, 2011, 9:25 AM
#16
yep ... stripping car ... my machine/weld shop is here soooooooo cold here ... warm there backwards I know.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
