Home
Go Back   ApexSpeed > General ApexSpeed Topics > General Formula Car Discussion
Reply
Thread Tools
Old July 18th, 2011, 9:06 AM   #1
Joe_914
Default Broke 2nd gear
After replacing the dog ring that was shot we got the car back to the autocross pad.
2nd run I snapped the little gear into 3 pieces.
How common is this? 15/37. Anything we can do to prevent this other than not autocross the car?
Sending the box to Taylor this week.
Joe_914 is offline   Reply With Quote
Old July 18th, 2011, 9:09 AM   #2
Marshall Mauney
Marshall Mauney's Avatar
What's the car, what type of gearbox, and whose gears?
Were the failures on upshift, downshift, or under acceleration? Shifting with or without clutch?
__________________
FE #64
Milwaukee Region
Marshall Mauney is offline   Reply With Quote
Old July 18th, 2011, 9:37 AM   #3
Joe_914
Ah sorry, I should put the car in my sig but it's not mine. I just get the lucky position of wrench and co-driver.
88 Van Diemen with a mk 9 4 speed box. Upshift acceleration no clutch.
No idea whose gears. they came with the car.
Old July 18th, 2011, 9:40 AM   #4
kea
Forum Advertiser
kea's Avatar
Sounds like a Mk series box.
If this is a "slide-on" gear, and if you look at the amount of material between the root of the gear tooth and the top of the layshaft spline, you will see there is not a lot of material there. The more steel, the better it will take the pounding.
In many cases, customers have little idea on the age of some of their gearsets. Could this be a case of it being used (often and hard for Autocross) past it's time?
I am not a fan of some "brands" of gears because I feel they will not hold up as well. That may be a case.
__________________
Averill Racing Stuff, Inc.
www.racing-stuff.com
248-585-9139
kea is offline   Reply With Quote
Old July 18th, 2011, 9:58 AM   #5
Dick R.
Dick R.'s Avatar
Joe,
Which R&P ratio? I think with a 9:31 you can run a "16 something" for second gear if you want the common 60 mph or less second gear. (I run a 17:34 but that's just me ). Buy a STRONG 16 or 17 from Keith.
Dick
85 VD
Dick R. is offline   Reply With Quote
Old July 18th, 2011, 10:15 AM   #6
You have to life the gears, or inspect them for pitting at the root of the teeth regularly. That plus the fact that a 15 tooth layshaft gear is just getting very small if it's a regular gear. You will break them with sticky tires and a hard shift into what is really a first gear ratio. Far better choice is a hubbed second gear, that has the spacer hub built onto the layshaft gear and is far stronger, also twice as expensive. When they built the MK 5 option they only offered integral first gears and hubbed second gears.
I hope I am not confusing 4 speeds and five speeds with the hubbed second gear idea...
Brian is offline   Reply With Quote
Old July 18th, 2011, 10:15 AM   #7
R. Pare
Forum Advertiser
Default Softer gears
One thing that autocrossers can do is what is common in drag racing - have the gears drawn back to RC 54-56, down from the RC62 that they currently are. This will make them slightly more ductile and able to withstand the shock loads longer.
Makes the gear teeth wear out faster if it ever goes back to road racing, though.
R. Pare is offline   Reply With Quote
Old July 18th, 2011, 10:41 AM   #8
Joe_914
Hmm, don't know the R&P ratio. Now with the gears out...........
Can I just turn the pinion shaft and count tire turns?
Old July 18th, 2011, 10:53 AM   #9
Dick R.
Dick R.'s Avatar
Yes. Remember that both tires need to turn together in the same direction.
Can you roll the car?
If not a 9:31 then probably a 10:31. 3.44 turns versus 3.1
Dick
Old July 18th, 2011, 10:58 AM   #10
Charles Warner
Charles Warner's Avatar
Chances are that the gear was just old. Chances are you can assume all your gears are old. Chances are 90% of the racers out there have no idea of the age of their gears. Brian is right. Life the gears. Keep records of how many miles/hours/events on them. Perform NDT on them once a year. It's easy and cheap, especially relative to tearing up a gearbox.
__________________
Charlie Warner
fatto gatto racing
Charles Warner is offline   Reply With Quote
Old July 18th, 2011, 11:11 AM   #11
-pru-
Global Moderator
-pru-'s Avatar
Default In a Solo application...
How common is this?
In 15+ years of running Solo with a MK9 box FF, I have broke three (3) 15:xx gears. Two were used of unknown life. One was a new 15:37 (2.47).
After breaking the new 15:37, I decided that move up one gear to a 15:36 (2.40) for the reasons noted above; the layshaft gear of the 15:37 just does have enough material to withstand the continual abuse in a Solo application.
As I found with the other two 15:36 gears, you need to lifetime these gearsets. That is, the best advice would be to buy a new, REM treated, M-series gearset and plan on replacing after ~200-250 runs (~3 yrs).
__________________
-pru-
Swift DB1 055-85
SCCA Solo C Modified (CM)
-pru- is offline   Reply With Quote
Old July 18th, 2011, 11:25 AM   #12
Jim Garry
Jim Garry's Avatar
In 20 years of running FF's in autocross, I have broken gears twice, maybe 3 times. They were all 15-37's. Pru is right about REM treating. But I ended up going to 16-xx gears and never had any more problems (knock on wood). If you have a 9:31 RP, you shouldn't really need a 15-xx anyway. As my car started handling better, i kept going up in gear ratio. So you could argue that improving the handling of your car saves you money in gears.
I also keep track of the age of my gear sets. Admittedly most are used and so I can't know their true age. But at least I have a record of when I obtained them and how much use they've had while in my possession.
BTW, I have one of my broken 15-37's on my desk at work that I use as a paper weight.
__________________
Jim Garry is offline   Reply With Quote
Old July 18th, 2011, 11:38 AM   #13
ghoneycutt
ghoneycutt's Avatar
Out of curiosity, what 1st gear is in it? I'm interested in the ratio spread between 1st and second.
__________________
SF86 Reynard FC
FRCCA http://www.formularacecarclubofamerica.com
Bill Scott Formula Car Series http://www.bsfcs.com
BMod Autocrosser http://www.nationalroadrally.com/
ghoneycutt is offline   Reply With Quote
Old July 18th, 2011, 11:57 AM   #14
Joe_914
My notes on 1st gear are 12/33.
Old July 18th, 2011, 12:11 PM   #15
ghoneycutt
ghoneycutt's Avatar
I'll assume that's 12/38. The spread is OK, although somewhat top-speed limiting in 2nd depending on where you autocross. I agree with the others, switch away from the 15/37
__________________
SF86 Reynard FC
Old July 21st, 2011, 11:51 AM   #16
Joe_914
R&P is 10:31
Old July 21st, 2011, 1:10 PM   #17
kea
Forum Advertiser
kea's Avatar
If you are going to continue on with Autocross as your main event, than you would find a 9/31 CWP better suited for gears (1-4) longer life. The ratios you would use will need to be increased about 3 teeth (total tooth count) to see the same speeds, which adds material where you need it.
__________________
248-585-9139
Old July 21st, 2011, 1:19 PM   #18
ghoneycutt
ghoneycutt's Avatar
Keith is correct about going up a few teeth with a 9/31.
I'm currently using a 9/31 R/P with a 12/38 first gear that's good for about 35 feet!
I've got a 13/37 fixed first but have not found time to install it yet.
__________________
SF86 Reynard FC
Old July 21st, 2011, 1:31 PM   #19
Dick R.
Dick R.'s Avatar
You might find that an approximately 66 mph at 6800 rpm second gear (17:34 with a 9:31 and either a 16:35 or 16:36 with a 10:31 according to this chart http://www.taylor-race.com/pdf/GearConversion2.pdf ) will give you the extra "beef" you need with the 10:31 if most of your courses are not "real slow" or don't have great traction. Your 1st gear appears to be good for about 45 mph so for the real slow corners just go back to 1st.
With this gearing you may find that the "upshifts" from second to third are far fewer and occur after you are actually on a "straight" instead of still in a corner. Make the spread between second and third pretty tight. Then have an "overdrive" fourth for any really quick "non SCCA" courses. Afterall, how quickly do you really want to accelerate between say 80 and 100 in a parking lot?
I've run this gearing for many years and used to be reasonably competitive before a long "layoff induced layoff from National level autocrossing).
Dick
Old July 21st, 2011, 3:58 PM   #20
Joe_914
Thanks Dick.
As to competativeness. I am willng to be as competative as the car owner wants to be. Only cuz I usually have him covered as far as time. (and I know he reads this thread)
In reality niether one of us as aspirations of winning a big shiny trophy. But it is more to run this car in a parking lot as opposed to say an H-stock car.
We really would like to compete in an event where we are not fussing with the car all day.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©ApexSpeed 2000-2013
