Board Members:
In the spirit of "Make it easy, make it fun", I would like to request a change to the rules covering the use of mandated or "spec" fuels.
It is clear that it is in everyone's best interest to control the fuels in use at our events, and many would argue that a mandated fuel selection, either single-spec or a selected list, is the most effective method for achieving this goal. However, I think it is equally clear that changing the fuel used in certain vehicles can create a significant amount of effort in tuning, and can risk damage to an engine. The range of specific gravities and stoichiometric ratios in available, currently-legal race fuels is wide enough to cause significant problems for teams whose cars have open-loop mixture control systems (such as FE), or systems with narrow control ranges.
Therefore, when a single spec fuel is mandated for a given event, such as this year's June Sprints, it creates a potential for problems in certain classes. This would be far easier to work with if the supps were to include the necessary relevant information about the fuel to be mandated; this information should include brand, blend/designation, specific gravity, stoichiometric ratio, and ethanol percentage.
As an example, the fuel information provided in the supps for the Runoffs is relatively complete, giving enough information for the competitors to source data from the manufacturer, and also giving time to work with the different allowable fuels prior to the event to insure that they work well in their applications.
In the case of the Sprints fuel, however, the only information given was octane level and "ethanol free", which is not enough information to either source detailed specifications or make preparations to run the fuel. "Run it and hope a piston doesn't melt" is not a rational approach to engine tuning, but that is what we are left with when insufficient technical data is available prior to an event.
In summary, while I am in favor of limiting the fuels that can be run at our events, I feel that when a spec fuel is mandated, we need to provide the competitors definitive identification of said fuel well prior to the event.
Thank you for your time and attention.
Marshall Mauney
Milwaukee Region FE #64
Nat'l Comp License 255530
