Home
Old May 31st, 2011, 9:03 PM   #1
Alex Brown Racing
Alex Brown Racing's Avatar
Default Stohr F1000
[FONT=Calibri]2007 Stohr F1000[/FONT]
[FONT=Calibri]Car model: Stohr F1000 Race Car (SCCA FB Class)[/FONT]
[FONT=Calibri]Car year: 2007, Chassis #017[/FONT]
[FONT=Calibri]Condition: Professionally maintained and ready to race[/FONT]
[FONT=Calibri]History: Delivered September 2007[/FONT]
[FONT=Calibri]2009 SCCA SOWDIV F1000 FB Class Regional Championship Winning Car [/FONT]
[FONT=Calibri]Asking price: $28,000[/FONT]
[FONT=Calibri]Car location: Houston, TX [/FONT]
[FONT=Calibri]Added Equipment[/FONT]
[FONT=Calibri]George Dean prepared 2006 Suzuki GSXR 1000 race engine (zero time fresh motor). [/FONT][FONT=Calibri]New chain (1 race [/FONT][FONT=Calibri]C2P Double Adjustable Dampers [/FONT][FONT=Calibri]700 lb. front and 800 lb. rear springs (stock 800# front and 1000# rears come with the car)[/FONT][FONT=Calibri]Stohr Ram air box intake with K&N filter[/FONT]
[FONT=Calibri]Two sets of BBS 1-piece Cast Magnesium Racing Wheels - (8 x 13) Front, ( 10 x 13) Rear[/FONT]
[FONT=Calibri]One set of mounted Hoosier R35A racing slick tires (brand new)[/FONT]
[FONT=Calibri]One set of BBS center lock 3-piece Aluminum Racing Wheels - (8 x 13) Front, ( 10 x 13) Rear [/FONT][FONT=Calibri]One set of mounted Hoosier rain tires (1 race)[/FONT][FONT=Calibri]Aim MyChron3 Gold XG Data Logging Digital Dash Display and data system w/wheel speed, [/FONT][FONT=Calibri]water temperature, oil temp, and oil pressure [/FONT][FONT=Calibri]AMB Transponder[/FONT]
[FONT=Calibri]Mk technologies alignment bars[/FONT]
[FONT=Calibri]Front and rear quick jacks[/FONT]
[FONT=Calibri]SCCA log book[/FONT]
[FONT=Calibri]The car is black with gold on the snorkel. Pictures are at www.alexbrownracing.net[/FONT]
[FONT=Calibri]Standard equipment:[/FONT]
[FONT=Calibri]Car Weight without driver 775 lbs., Wheelbase 99”, Front Track 64”, Rear Track 61[/FONT]
[FONT=Calibri]Powder Coated Steel Tube Space Frame Chassis[/FONT]
[FONT=Calibri]Super Strong, Light-Weight, Vacuum-Bagged, Oven-Cured, Pre-impregnated Fiberglass Bodywork [/FONT]
[FONT=Calibri]and Composite Front and Rear Wings[/FONT]
[FONT=Calibri]FIA-Style Energy-Absorbing Composite Nose Section, unique to the Stohr F1000[/FONT]
[FONT=Calibri]Full Ground Effect Downforce Rear-Diffuser Tunnel Floor[/FONT]
[FONT=Calibri]Pushrod suspension on all four wheels, front and rear[/FONT]
[FONT=Calibri]Quaife Limited Slip Differential with Fully-Machined “Stohr Spar”[/FONT]
[FONT=Calibri]Willwood Master Cylinders with Stohr CNC Machined Pedal Assembly[/FONT]
[FONT=Calibri]Stohr Specific Machined Fully-Floating Brake Rotors on lightweight Billet Aluminum Brake Hats[/FONT]
[FONT=Calibri]Willwood Billet Aluminum Brake Calipers – 4 Piston Front , Twin Piston Rear [/FONT]
[FONT=Calibri]Cockpit Adjustable Brake Bias Control[/FONT]
[FONT=Calibri]MOMO Suede Steering Wheel with SPA Quick Release Hub[/FONT]
[FONT=Calibri]F1 Style Steering Wheel Column Mounted Billet Aluminum Sequential Paddle Shifter[/FONT]
[FONT=Calibri]Aluminum Water Radiator Custom Made for Stohr Cars [/FONT]
[FONT=Calibri]AFFF Fire System with two outlet nozzles per SCCA GCR 17.22.[/FONT]
[FONT=Calibri]SCCA homologation certificate[/FONT]
[FONT=Calibri]For further details, contact:[/FONT]
[FONT=Calibri]281-920-2671[/FONT]
Alex Brown Racing is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©ApexSpeed 2000-2013
