Home
Old May 7th, 2011, 3:26 PM   #1
Monte
Default Aluminum Alloy for Wing plates
Does anyone know what alloy or what specific aluminum I can make my front wing end plates for a 98 Van Diemen? Thanks
Chris
Monte is offline   Reply With Quote
Old May 7th, 2011, 5:19 PM   #2
cerojo
Default Alloy Al plates are
of different alloys available. The end plates are NOT a structural part unlike the support plates. The important issue is plate thickness and for end plates I would use .080"-.090" any aluminum alloy that you can get: 6061T6, 2024T3...etc.
cerojo is offline   Reply With Quote
Old May 7th, 2011, 7:11 PM   #3
Monte
Thank you for the response.
CM
Old May 7th, 2011, 7:27 PM   #4
10rmotor
.060 aluminum, any alloy and hardness is fine. I've made structural wing supports from .060 6061 T6, and while they needed some support worked fine for years, so for a non-structural panel or endplate its probably overkill.
10rmotor is offline   Reply With Quote
Old May 7th, 2011, 9:04 PM   #5
Becker Motorsports
Becker Motorsports's Avatar
I used .093 6061-T6, for front and rear end plates with no problems. allthough I use Guy wires on the rear endplates to prevent any possibility of flexing.
Becker Motorsports is offline   Reply With Quote
Old May 7th, 2011, 9:44 PM   #6
RobLav
RobLav's Avatar
I use balsa wood, S-glass, and epoxy!
__________________
Rob
08 Citation Dual FB/FC
RobLav is online now   Reply With Quote
Old May 8th, 2011, 1:49 AM   #7
Bob Coury
Bob Coury's Avatar
I use G-10 sheets (already black) from McMaster.
http://www.mcmaster.com/#grade-g-10-...-stock/=c7l6yc
Bob Coury is offline   Reply With Quote
Old May 8th, 2011, 4:20 PM   #8
Steve Demeter
Steve Demeter's Avatar
to r4eally save weight go to the local plastics store and get some drops of HDPE sheet.
Will cost like nothing if they have any and weigh even less
Steve Demeter is offline   Reply With Quote
Old May 8th, 2011, 4:28 PM   #9
Hardingfv32
RobLav
What thickness balsa and what general finished thickness? Do you have a mold for both sides of a given end plate?
Hardingfv32 is offline   Reply With Quote
Old May 8th, 2011, 8:17 PM   #10
Pop Chevy
Pop Chevy's Avatar
I use .060 alum T-6. BUT, i like the idea of the G-10. Bob, is it paintable ?
Pop Chevy is offline   Reply With Quote
Old May 9th, 2011, 3:46 AM   #11
Bob Coury
Bob Coury's Avatar
It should be as we did an experiment at work where we had some .25 thk panels and we painted one side with marine type epoxy paint. I liked it because It did not have to paint it to use for my front wing end plate. I may even make a dash with it.
But be aware that I ad to use a abrasive tyoe of jig saw blade to cut it.
If you are going to paint it anyway, they also have green fiberglass sheets:
http://www.mcmaster.com/#fiberglass-...sheets/=c8581h
Old May 9th, 2011, 7:46 AM   #12
ASRF1000
Guest
Posts: n/a
Monte, How much area (dimensions) do you have to play with as far as overall front wing width. Do your end plates have to be flat?
Old May 9th, 2011, 8:00 AM   #13
ASRF1000
Guest
Posts: n/a
Monte,
I have a set of light weight aluminum end fences we made up for our F1000 if they can be of use to you. See pics.
Old May 9th, 2011, 8:02 AM   #14
RobLav
RobLav's Avatar
That 1/4" thick HPDE sounds like a pretty good thing. Much faster than epoxy.
Brian - I've used 1/4" balsa sanded a bit in the belt sander. The balsa needs a coat of epoxy on both sides to harden before using the glass, otherwise the epoxy will soak in the wood and you won't get a good bond. No molds - just cut to what I want to produce - and I use an old greasy shower curtain as the non-stick.
__________________
Rob
Old May 9th, 2011, 10:28 AM   #15
Monte
Default endplates
My endplates are flat with the Whizzy Bits on the side adding 2 inches on each side in total wing width. I have the moustache wings on a 98 Van Diemen
Old May 10th, 2011, 8:09 PM   #16
monte442
That's a nice car mister.
monte442 is offline   Reply With Quote
Old May 10th, 2011, 8:45 PM   #17
Monte
Ah, Thanks monte442. Its got a sweet motor. Tons of work done by me and my Bro to get it done. He does great work.
Old May 10th, 2011, 9:04 PM   #18
ASRF1000
Guest
Posts: n/a
Monte,
The endplates I have (as shown in above post) are 2 " wide.
Old May 10th, 2011, 10:56 PM   #19
stonebridge20
stonebridge20's Avatar
Quote:
Quote:
All it needs is a Stonebridge sticker !
__________________
(203)744-1120
stonebridge20 is online now   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©ApexSpeed 2000-2013
