For Sale, new
Bertils USF-3 2.0L #10 motor. This was a spare for motor #02 which is also available for purchase.
According to Bertil Sollenskog, these motors were "bulletproof" and considerably undertuned in USF-3 tune for series longevity and driver safety. They can make more power safely. In current tune, makes 199.9hp @ 7200rpm.
Engine
- Engine Builder: Bertils Racing Engines
- Manufacturer: Volkswagen
- Displacement: 2.0l
- Horsepower: 199.9@7200rpm
- Torque: 162.6ft/lbs@5200rpm
- Induction: 46mm TWM ITBs, electronic fuel injection
- Heads: Full race Bertils treatment
- Block: AEG VW
- Crankshaft: 92.8mm Forged, polished and balanced
- Connecting Rods: 144mm Carrillo forged, balanced and polished
- Pistons: 82.5 forged Wiseco
- Camshaft: 301* BRS F3 grind
- Valves: Intake 40.5mm, exhaust 35.0mm
- Valve Train: see below
- Flywheel: Formula 3
- Exhaust: n/a
- Total Time: zero
- Races: zero
- 12.4:1 Compression Ratio Full dry sump Lifters BRS 37mm, shim under buckets Valve springs BRS 37mm Germany Retainers BRS Titanium ARP bolts and studs installed as follows: main studs, rod bolts, head studs
NEW PRICE
This is a NEW motor, not rebuilt, zero hours since leaving
Bertils Racing Engines facilities. Motor #10 is available for
$5000.00 and includes one engine loom and 46MM TWM Throttle bodies cast specifically for these engines and no longer available from TWM.
Motor #02 is also available with 46mm TWM ITBs port matched to this engine. Motor #02 has dyno time only judging by the carbon deposits on the exhaust ports. Motor #02 is available for
$3500.00
This is my lowest price, will not entertain any other offers.
Shipping is extra.
A Pectel T-2 ECM with optimized USF3 engine maps can be provided for an additional $1500.
Thanks for looking
RC
Edit: I forgot to mention, these motors are physically in the USA, upper state NY to be specific.
