Reynard FF83/4
Justice Racing Engine, Pro built motor with Dyno sheets, SCCA crank,new cam,new CP pistons,new mains and rod bearings
CCH Aluminum head and prepped carb (spare rebuilt cast iron head included)
Lightened Flywheel
Hi-tech exhaust-"Tri-Y" header w HPC coating
Taylor Race Engineering-Hewland gearbox-blueprinted
Two Dogs Aluminum Differential
Hewland gear box with fixed layshaft
Tilton F3 clutch w/hydraulic conversion
4.5 F/F S2000 racing starter
Fox Penske-Custom "foxske" shocks
Drilled brake rotors with Aluminum Hats ( saves 12# over stock)
TDI stub axels & halfshaft
Momo stearing wheel with Quick release
Aurora rod ends/spherical bearings
Panasport wheels with Hoosier (one solo event on tires)
Set of Compomotive wheels with Hoosiers
Set of Revolutions with Hoosier rains
Hewland road race gears
Internal sway bar adjustment
Electronic ignition
SPARES: One Nitrogen tank with gauges and Penske vale for charging shocks, One Smartcamber Gauge, 6 sets of Eibach springs 200 400 800 175 250 300 , Two noses, $ Bilstein shocks ,Rebuilt cast Iron head never used, stock header , rotors, pads, spare lay shaft, much much more
$10,750.00
PACE AMERICAN TRAILER
"BOSS" edition all Aluminum
Special cabinet package with full stand up locker
Aluminum Tire Rack
2000# internal winch
Rubber matted floor
Beaver tail entrance with fold down ramps -spring assisted
Spare tire compartment in floor
2500# electric nose jack
Carbon Dioxide "Power Tank" to inflate 50 truck tires with gauges,gauge protector
Electric brakes
3500# axles
2-4' electric interior lights, 2-500 watt exterior lights, smooth metal exterior black finish(no exposed rivets, 110volt wall switch,30amp panel with life line,Aluminum wheels, 24" stone guard, 4 "D" rings, roof vent, 4 dome lights, rear ramp door locks, 12 volt breakaway switch, door storage cabinets , chair storage
$7,500.00
Both unit package $17,500
ptrckbullis@yahoo.com
