Home
Go Back   ApexSpeed > General ApexSpeed Topics > General Formula Car Discussion
Reply
Thread Tools
Old December 12th, 2010, 6:12 PM   #1
drdestructo
drdestructo's Avatar
Default Rubber shock reservoir mounts
shockmount.jpgAnyone know where to get the little rubber pieces that go between the chassis and a Penske 8100 remote shock reservoir? I lost one last season and would like to replace it.
Russ Werner
drdestructo is offline   Reply With Quote
Old December 12th, 2010, 6:29 PM   #2
Mike B
Global Moderator
Mike B's Avatar
A chunk of heater hose?
Could you make something like this work?
Penske clamp
__________________
RF99 F1000
Get your 2013 Formula Car calendar HERE!
Mike B is online now   Reply With Quote
Old December 12th, 2010, 7:36 PM   #3
drdestructo
I don't think I have room for the piggy back style you show. I'd sure like to find something nicer than heater hose!
Russ
Old December 12th, 2010, 8:25 PM   #4
john f
Default spacer
either cut from a pc of plastic or buy a pc of sheet rubber and cut from that.
john f
john f is offline   Reply With Quote
Old December 12th, 2010, 9:40 PM   #5
S Lathrop
Check Earls Supply in Indy. That is where I got those the last time.
S Lathrop is online now   Reply With Quote
Old December 13th, 2010, 7:39 AM   #6
BWC54
BWC54's Avatar
Prothane makes some universal shock reservoir mounts. The smallest they make is 2" x 1.5" though so you don't get a good fit on the frame side.
__________________
Crossle 32F, Swift DB-1 049-84, Piper DF5 #032
BWC54 is online now   Reply With Quote
Old December 14th, 2010, 5:39 PM   #7
drdestructo
Default Got 'em
Anita at Indy Motorsports had them. Thanks for the ideas.
Russ
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©ApexSpeed 2000-2013
