Hi guys,
I haven't posted anything here in a while, but I stop by frequently to keep up on the F2000 news.
I read all the posts including the long winded and often amusing posts by some of the more colorful members.
I have to make a couple of corrections that I have read about Nascar Heat physics that may be misleading to some of you.
(I will paraphrase this rather than dig the quotes up)
1. The F2000 has Nascar car shell that you can not get rid of.
Not true. We can specify the length width and height of the body.
the physics file reads:
mx 35749
my 46446
mz 7849
These are the mass values of the car itself. This uses a complex formula to calculate the final numbers you see here.
width 70.0
height 37.0
These figures tell the Game engine how big the body is.
ftrack 65
rtrack 59
wheelbase 102
These figures tell the game engine where the tires are. (track is from the inside of the wheels).
You can prove that you are not driving a "Nascar shell" by going out and locking wheels with another car and see what happens.
2. You do not have a front wing. it is grill tape and that can not act as a front wing.
Completely false.
fspoiler_lift -.0, -.59
fspoiler_drag .016, 0.16
rspoiler_lift -0, -.80
rspoiler_drag .0201, .201
We can control all aspects of the front wing to make it is large or as small as we wish, as well as add the required amount of drag for each wing.
You say that the car overheats when you put the wing at the higher settings and that is why it is "grill tape". the reason is because Heat ties in engine friction to the amount of front wing. I may have not reduced the friction enough to negate that.
3 Nascar has a canned slide when you put the car sideways.
Not true.
I don't know any other way to explain this as it is a function of weight, tire grip. and roll centers of the physics.
to test this, go download our Lotus F3 and slide it around. Then download our Ferrari Challenge and slide that around.
The cars are very different. True you can slide any car to the point of no grip and you will loose it, but how many times have you saved the car even after you have done a 360?
I wanted to clarify a few things about Nascar Heat that my have made some people think that this was still a 3000 pound hunk of heavy metal with an F2000 body.
