Home
Go Back   ApexSpeed > Formula 1000 > FB: Car Building
Reply
Thread Tools
Old June 21st, 2010, 10:07 AM   #1
peat
Default Symmetrical streamline tubes and adptors
Hi all
I would like to know where can I find that kind of tubes and adptors. I think that I can find the tubes easilly here in europe, but I am not sure about the streamline tube adaptors, anybody knows something about them?
I just find the following pic of the adaptors
Thank you
peat is offline   Reply With Quote
Old June 21st, 2010, 11:10 AM   #2
Wren
Not an aerodynamicist
Wren's Avatar
Most people make their own adapters by using a generic spherical bearing housing and cutting and shaping the aero tube around the housing. The one in the photo looks kind of neat, but the only place I could imagine using it on a car would be the steering. I don't think I have ever seen a car at the track using those kind of adapters.
Depending on your machine shop capabilities you can have a spherical bearing housing made up that has a flat extension running off of it to go in to the aero tube and then you only have to shape and fit the aero tube around something flat instead of around a bearing housing.
Wren is online now   Reply With Quote
Old June 21st, 2010, 12:14 PM   #3
peat
Thank you wren, I know that most people do it by themself and that is my first option, but i was on the web when I find that pic (it is just only an example) and think that, may be, in some where someone build it.
Thank you
Old June 21st, 2010, 12:57 PM   #4
DMac
DMac's Avatar
IIRC, The Chassis Shop (www.chassisshop.com) sells them as well as the streamline tubing.
__________________
David McMahon
Team Principal, McMahon Raceworks
2013 Lotus Evora GX in the GRAND-AM Rolex Series
McMahon Raceworks FB mothballed for now
DMac is offline   Reply With Quote
Old June 21st, 2010, 1:15 PM   #5
peat
Quote:
Thank you DMac, do you know if they sell symmetrical streamline tube?
Old June 21st, 2010, 1:40 PM   #6
peat
Default symmetrical streamline tube
duplicate post
Old June 21st, 2010, 1:56 PM   #7
DMac
DMac's Avatar
Found you the direct link:
http://secure.chassisshop.com/partlist/5913/
__________________
David McMahon
Old June 22nd, 2010, 9:28 AM   #8
peat
this kind of tube are allow in Fb suspension members?
Thank you
Old June 22nd, 2010, 10:06 AM   #9
RobLav
RobLav's Avatar
Yes
__________________
Rob
08 Citation Dual FB/FC
RobLav is offline   Reply With Quote
Old June 22nd, 2010, 10:16 AM   #10
Jnovak
Forum Advertiser
Jnovak's Avatar
Low cost symetrical oval tubing is available from Piontek Engineering. He has dies for several sizes. We use his tube for all of our cars as the cost is MUCH lower than true aero tube.
We do not use the commercially available adaptors for aero tubes due to the cost plus there is no technical advantage to them. Simple threaded tubular bungs or machined housings are the best way to go.
Call Dave Piontek at: 810-991-1148
Jnovak is offline   Reply With Quote
Old June 22nd, 2010, 1:49 PM   #11
peat
Thank you Jnovak, I am thinking about all the available options.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©ApexSpeed 2000-2013
