Home
Old March 27th, 2010, 5:08 PM   #1
Marshall Mauney
Marshall Mauney's Avatar
Default Tripod lube question?
A quick question - I have new tripod joints to put into my car, along with a really nice little joint lubing tool and a tube of GKN tripod lube. Here's the problem: The lube tool has a normal grease fitting, but the grease tube appears to be more like a caulk tube than a normal grease tube. It has a thread for a nozzle, not an opening to fit into a grease gun.
Anybody else tried to use these things together? Is the tripod lube tool just basically worthless with this lube?
__________________
FE #64
Milwaukee Region
Marshall Mauney is offline   Reply With Quote
Old March 27th, 2010, 5:20 PM   #2
Tifosi
Tifosi's Avatar
I load the grease into a mini grease gun and then use the tripod fitting Marshall.
__________________
Dave
Tifosi is offline   Reply With Quote
Old March 27th, 2010, 6:13 PM   #3
carnut169
Global Moderator
carnut169's Avatar
Quote:
Yep. use the tool- works great.
__________________
Sean O'Connell
1996 RF96 FC
1996 RF96 FB
2004 Mygale SJ04 Zetec
carnut169 is offline   Reply With Quote
Old March 27th, 2010, 6:25 PM   #4
Marshall Mauney
Got it - that makes sense.
Thanks guys!
__________________
FE #64
Milwaukee Region
Old March 30th, 2010, 3:02 PM   #5
SCOTTY81
SCOTTY81's Avatar
Marshall.
On the very top of the fitting where the ball is.
Touch this part with a small grinder . This will allow the ball and a small spring to pop out.
Home Depot sells small clear tubing , slip this over the pointed end on the grease cartridge.
and push the other end over the grease fitting.
scotty
__________________
Scotty
Taylor Race Engineering
Hewland
Webster
Tilton
Quarter Master
SCOTTY81 is offline   Reply With Quote
Old March 30th, 2010, 3:26 PM   #6
Jeff Read
Jeff Read's Avatar
Nice idea Scotty.
__________________
JR
"Of all the things I've lost, I miss my mind the most ! "
Jeff Read is offline   Reply With Quote
Old March 30th, 2010, 3:37 PM   #7
SCOTTY81
SCOTTY81's Avatar
Thanks Jeff.
We sell a bunch of those tools....and grease.
That seemed to be the best solution.
The least messy that is..
__________________
Scotty
Hewland
Webster
Tilton
Quarter Master
Old March 30th, 2010, 5:13 PM   #8
SStadel
Forum Advertiser
SStadel's Avatar
The one we have does not have a grease fitting. It has an opening big enough for the tube from the caulk gun to fit in it. Must be a different tool.
__________________
One Formula Racing
Central Division FE CSR
Central Division National Champ FE '09
www.oneformularacing.com
racer6@mchsi.com
SStadel is offline   Reply With Quote
Old March 30th, 2010, 5:57 PM   #9
Kevin Kloepfer
Default Grease Tool
We make an adaptor for the grease tool that goes between the tool and tube. Kevin at comprent motor sports
Kevin Kloepfer is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©ApexSpeed 2000-2013
