Home
Go Back   ApexSpeed > Formula 1000 > FB: Car Building
Reply
Thread Tools
Old November 30th, 2009, 9:20 PM   #1
Roux
Roux's Avatar
Default Where do Idler Sprockets come from?
I need an idler sprocket and have sketched up ways to stuff a 26x10x8mm SKF bearing into a machined out 15 tooth sprocket. Then I did a google search and ended up in the buggy websites where they accept a teflon rubbing block as a good solution. What have you guys done to get something like a 15 tooth sprocket with bearing(s) to build in as an idler.
Roux is offline   Reply With Quote
Old November 30th, 2009, 9:27 PM   #2
Northwind
Northwind's Avatar
Contact Jay at novaracecars.com.
They have a set up that you could probably use. It should be reasonably priced.
Northwind is offline   Reply With Quote
Old November 30th, 2009, 9:28 PM   #3
formulasuper
formulasuper's Avatar
Default Google it
Quote:
Try Google. Lots of sources.
__________________
Scott Woodruff
formulasuper is offline   Reply With Quote
Old November 30th, 2009, 9:42 PM   #4
carnut169
Global Moderator
carnut169's Avatar
Ditto. I got some from McMaster Carr. No need to build your own, they do come with bearings.
__________________
Sean O'Connell
1996 RF96 FC
1996 RF96 FB
2004 Mygale SJ04 Zetec
carnut169 is offline   Reply With Quote
Old November 30th, 2009, 10:05 PM   #5
Roux
Roux's Avatar
Default Thanks
Just ordered from McMaster.
Old November 30th, 2009, 11:01 PM   #6
Beartrax
Beartrax's Avatar
Default Daddy, Where do Idler Sprockets come from?
When a daddy Idler Sprocket and a mommy Idler Sprocket love each other very much...
__________________
Barry Wilcock
Pit Crew
Fat Boy Racing
Beartrax is offline   Reply With Quote
Old December 1st, 2009, 9:22 AM   #7
glenn cooper
All Knowing One
glenn cooper's Avatar
Default Is a stork involved?
The Mommy's stomach?
glenn cooper is offline   Reply With Quote
Old December 1st, 2009, 1:52 PM   #8
formulasuper
Quote:
What did you do with the two I gave you?
__________________
Scott Woodruff
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©ApexSpeed 2000-2013
