The car is in perfect shape. People say that a lot but this car is perfect and the set up is perfect too. It turns 1:21's at Willow on the big track. We won our last event there. We have tested at Buttonwillow and were pleased enough to load the car and go home half way through the day. Pi dash and data system. We have all the software and instruction manuals. The car comes with three set of O Z wheels. I have 7 full sets of Goodyear 250's with one race on them. I also have 1 set of Goodyear 160's. I have two set of Goodyear stickers that have been only scrubbed and they are 160's and 250's as well. All tires are kept in the matching sets as they came off the car. I am offering the car and the trailer you see in the picture. I am offering the trailer as you see it with all of it's contents down to the tools. There is a brand new air compressor, cooling fans, all the necessary hand tools, storage cabinets, tire racks that hold two full sets of tires, custom built shelving in the front, tool chests. The trailer has black marble looking vinyl flooring that is perfect with no damage. The trailer is an '07 but bought new five months ago. The trailer has a fold down sofa/bed, gas can rack with the cans, oil storage cabinets, hose holders, formula car jack, regular racing jack, flashlights, spray can rack and necessary lubricants in the racks. The trailer also has a solar battery charging system and battery for the new heavy duty hydraulic jack custom mounted on the front. The trailer is light and narrow. Everything fits perfectly into the trailer and you can haul it with a standard 1/2 ton truck. You will even be able to see behind you without the fancy mirror extensions. I have made this trailer and complete set up so easy to use that you will never tire of going to the track with this rig. The trailer has fold down custom extension ramps and you never even have to steer the car. They are perfectly aligned for the car to roll right off even if you suck at steering it.
Send me a PM or call me at 805-236-5369 and I will try to answer any question you have. The car is professionally maintained and he is also available to answer questions too.
I will post as many pictures as I can and if you need more just ask and I will send over a file of recent pictures.
Remember, just make an offer and I just might take it. Try not to insult my intelligence or your own for that matter. People are watching....
Good luck and I hope to hear from you soon. Thanks, Robert.
History
ex Cory Witherwill USAC Pro F2000 car (4th or 5th overall in series)
Performance Data
Engine
- Class: F2000
- Weight: 1050 lbs
Fuel System
- Engine Builder: Quicksilver
- Manufacturer: Ford
- Type: OHC
- Displacement: 2 litre
- Horsepower: 155
- Induction: Weber carb
- Heads: Quicksilver prepared Ford
- Block: Ford
- Clutch: Tilton
- Pressure Plate: Tilton
- Exhaust: Van Diemen
- Total Time: 3 races
Oil/Water System
- Fuel Cell
- Manufacturer: Van Diemen
- Age: 4 yrs
- Capacity: 8 gal
- Fuel Pump: Mechanical
- Fuel Type: 114 Octane
Electrical System
- Radiator: aluminum
- Water Rad Location: 2 side pods
- Water Pump: Ford
- Oil Cooler: yes
- Oil Cooler Location: left sidepod
Transmission
- Ignition: electronic
- Alternator: no
- Battery: Odyssey (new)
- Data Logger: PI-2
- Computer: PI-2
Rear End
- Manfacturer: Hewland
- Type: LD200
- Gears: 4 speeds
- Shifter: manual H
- Trans Cooler: no
- Races: 5 hours
Body
- Manufacturer: Hewland
- Type: in unit with gearbox
- Cooler: no
- Case: aluminum/magnesium
- Axles: gun drilled steel w/cv joints
- Races: 5 hours
Chassis
- Construction: fibreglass nose, cowl, sidepods and side panels, engine cover, alloy wings
- Color: blue/yellow decals
- Paint: PPG
- Condition: excellent
Interior
- Type: spaceframe
- Builder: Van Diemen
- Material: chrome moly
- Finish: epoxy paint
- Front Suspension: pushrod, anodized aluminum, excellent
- Rear Suspension: pushrod, anodized aluminum, excellent
- Shocks: penske 3-way, 5 hours
- Brakes: drilled rotors
- Steering: rack and pinion
- Wheels: 3 sets of OZ
- Tires: Goodyear total of 10 sets.
Spares
- Color/Finish: black
- Material: fibreglass seat
- Fire System: 5 lb manual
- Restraints: Willans
- Guages: PI-2
- Steering Wheel: momo
- 2 sets wheels, 3 total sets of wheels.
- complete pro race effort
