Home
Go Back   ApexSpeed > General ApexSpeed Topics > General Formula Car Discussion
Reply
Thread Tools
Old October 4th, 2008, 1:31 PM   #1
Bob Coury
Bob Coury's Avatar
Default 8 Point Star bits
Does anybody know where I could find these? Tried McMaster, local parts stores. Need them to removes some screws on a Pace trailer. The screw heads resemble a torx, but have 8 points instead of 6.
Bob Coury is offline   Reply With Quote
Old October 4th, 2008, 1:53 PM   #2
Paul LeCain
Just use the right size square bit. That's what I use on my Pace Trailer.
Paul LeCain is offline   Reply With Quote
Old October 4th, 2008, 2:37 PM   #3
I use a Robertson (square) bit as well, after spending at least $30 buying three different bit sets of Torx, etc... They ain't a standard screw, except in the trailer industry!
Brian is online now   Reply With Quote
Old October 4th, 2008, 2:45 PM   #4
jcorsico
Quote:
My trailer (a Mission; which is essentially a Thule) has the same screws. After looking quite a lot for the bits, I gave up and called the factory - they said you can buy an expensive 8 point bit, or just use a #2 square drive, which is what they actually use in the factory so they don't have to buy the expensive bits.
Jon
jcorsico is offline   Reply With Quote
Old October 4th, 2008, 3:24 PM   #5
ChrisInAtlanta
ChrisInAtlanta's Avatar
One more vote for using a square drive bit. It works like a charm for me.
I needed to tighten a few screws on my Pace a while back, at a friend's who has, say, 16 12mm wrenches, 8 cheap grinders, etc. He was shocked to learn that he didn't own a bit that fit. . . I am sure that he does now. Nice custom race car, with dyno for the engine, in his shop, which is bigger than his house. . .
Chris
ChrisInAtlanta is offline   Reply With Quote
Old October 5th, 2008, 12:06 PM   #6
Bob Coury
Bob Coury's Avatar
Thanks Guys. The square drive does not work when trying to loosen really tight ones. I will see if I can bum one from a local trailer place.
Old October 6th, 2008, 12:36 AM   #7
DorBell
DorBell's Avatar
Northern Tool. Inexpensive sets of hardened 8 or 12 point bits.
DorBell is offline   Reply With Quote
Old October 6th, 2008, 11:38 AM   #8
steve zemke
Got mine from Pace Parts department
steve zemke is offline   Reply With Quote
Old October 6th, 2008, 11:41 AM   #9
Tom Sprecher
Tom Sprecher's Avatar
Beat the bit into the head of the screw with a hammer and try again. Works for phillips as well that have been buggered up by camming out. Also try a hand impact driver if that doesn't work.
__________________
Tom Sprecher
ATL Region Treasurer
Tom Sprecher is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©ApexSpeed 2000-2013
