As part of my research into FF I'm trying to get a handle on the operating budget.
My first point of confusion is on engines. I have been doing a lot of reading in the archives as well as talking to a few people and I have heard rebuild costs are $3500 to $8000 and from every year to several years and from 20 hrs to 50 hrs. Is there a realistic number or are all of these numbers correct?
Here are the regional rules for SEDIV SCCA. What (if any) affect do the following rules have on an operating budget? I did a search on the R60 and found info on tire pressures and setup info, but nothing on life expectancy. What is the life expectancy of the R60 tire?
Permitted modifications: (Nothing in these permitted modifications shall supersede restrictions as set forth in the GCR.
· Club Ford cars may be up-dated provided the basic configuration is unchanged. Heat exchanges shall not be relocated to an inboard position amidships and suspension(s) and front brakes shall not be converted to inboard configuration.
· The manufacturer’s basic body design shall be used. Aluminum substitute or one-of bodies are permissible only if original body work is unrepairable or unobtainable; however variant should conform in appearance and dimension to original.
· Use of carbon fiver type material is prohibited. Aluminum underbodies/skidpads are permitted.
· Coil springs, shock absorbers, anit-roll bars, steering rack and wishbones are free provided they fit the original locations.
· Make and update of drive shafts is free.
· Any modification of which the sole purpose is to increase driver safety is allowed.
· Club Formula ford cars shall carry the class identification of CF governing identifying marks.
· Spec Tire Hoosier R 60
Thanks!
