1980 Zink Z-16 Club Formula Ford
Car was run in 2007 East-West Challenge (CenDiv & Great Lakes SCCA). Always ran strong, finished 2nd in points with rookie driver. The car was always a pleasure to drive, behaved well, and is capable of running up front as is. The car is completely race ready. It could be on the track today. I am only selling this car because I quickly became hooked on FF, have already bought a newer FF, and need the garage space. For those not familiar with the Z-16 design, it is probably the most modern design CFF you can find. Inboard rocker front suspension. And the rear of the car un-bolts from the firewall back, similar to more modern cars. This makes the car very easy to work on. Everything on the engine is easily accessible, unlike other full-frame CFF’s. This car can also accommodate larger drivers. There is plenty of room in the cockpit.
Strong Engine
13 gear sets
2 bead seats
Willans FIA harness (good through 2008)
4 sets of wheels: 3 sets Centerlines (2 with R60’s, 1 with nearly new Hoosier rains). One front centerline wheel is slightly damaged, but probably repairable. 1 set of 3 spoke Compomotives
Odyssey battery
Aluminum radiators
Some miscellaneous suspension spares
Extra front bearing (new)
Extra front hub (new)
4 extra pairs of springs
Hardwired transponder
Wired for radio (radios not included)
All AN suspension hardware
I bought this car at the start of last season, and went about replacing any parts that were suspect. All of the items listed below were brand new last season:
All master cylinders
All brake and clutch lines
Calipers rebuilt with all new seals and all new stainless steel pistons
Front hubs
Front bearings
Hyperco springs
Shift linkage joints
Throttle cable
Momo chopped top steering wheel
SPA mirrors
I also had some custom machined sleeves made for the front hub/bearings. These pieces solved some front wheel bearing issues that I had.
Can deliver if you are close to Indiana. Email or post here with any questions.
$8000
Brad Hayes ( bradhayes@insightbb.com )
