Home
Go Back   ApexSpeed > General ApexSpeed Topics > General Formula Car Discussion
Reply
Thread Tools
Old April 6th, 2006, 11:49 PM   #1
Joe911
Joe911's Avatar
Default spring length
I will be experimenting with some stiffer springs over the next several months. Is there any advantage or disadvantage related to spring length? 1975 Titan FF outboard front spring/Spax shock unit with motion ratio of 2:1. Currently with 6" front springs and 1/9/16" of thread showing above the spring perch so I could use a 7" spring. I suppose that the 6" is lighter??
Thanks in advance, Joe Riley
Joe911 is offline   Reply With Quote
Old April 7th, 2006, 3:04 AM   #2
Roger Eade
Default Spring
It does not matter how long your spring is, the lenght does not determin the poundage of the spring, this done by, heat treating, materials, and diameter of steel used, and any good race shop will be able to tell you what weight your springs are and able to advise as to what you may need, you can always ask some one in a similar car, what his set up is, and you can use as a base, it may not be the correct one for you as everyone has a different style of driving, but it will give you a start. This of course will take years, as I am still chasing set up, and just when I think I have it right, I come up with another idea! but thats racing!
Roger
Roger Eade is offline   Reply With Quote
Old April 7th, 2006, 8:31 AM   #3
Default Spring length
The only thing I've been able to come up with on this is weight (and do they fit on your shocks). A shorter spring can use a lot less material to get the rate than a longer spring, whcih would normally have more coils and larger diameter wire. That's probably why really soft springs are usually longer than stiffer springs. I'm trying to standardise on 6" springs for convenience.
Brian is offline   Reply With Quote
Old April 7th, 2006, 8:34 AM   #4
AJWALKER
AJWALKER's Avatar
There is no techincal gain from using a longer spring of the same lb/in rate. I would make sure of the clearance required to remove the spring from the shock before using a longer spring, some spring keepers require about an inch of free space to remove. Some times going shorter will save weight, but you must be carefully of coil bind.
AJWALKER is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©ApexSpeed 2000-2013
