    Senior Member beachguy12's Avatar
    CA
    Liked: 29
    Default Bead Locks Leaking
    Just had some new tires mounted and my bead locks are leaking. I want to put O-rings under the bolt heads but the rim is not chamfered for the O-ring. Will the lack of a chamfer cause the O-ring to leak or lead to other problems? Any other ideas?
    Santa Rosa, CA
    Liked: 268
    Default bead locks leaking
    You can use stat-o-seals which should take care of it.
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 592
    Default Bead Locks leaking
    I use Hylomar on the bolt threads. Let dry (15 min) and assemble.
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
